What LS2 sensors are you talking about?
Crank and cam, LS1 to LS2 are pined backwards, learned that the expensive way. Bought new sensors before I found the information
You have an 8.1.........
The 2004 8.1 uses the LS2 sensor stratagy if that makes sense
It uses a different cam position sensor not crank. The reluctor and timing cover is different as well. You cant just change the sensor.
Was you engine originally an 04?
04 already had the new sensor style. Interested in what exactly you swapped
