6243
Drive by cable? If it is, I'll have to rework the file I put up. What BASE file did you use?
The current file started out as the original 8.1DBW/Allison, 4L80E segments swapped in, and everything that I could find switched over to DBC even went through the transmission stuff to. Used a 6.0 TB
Cool, file I sent was setup for wire. Just set it up the same way for cable as you did the other file.
Does that have the lift shift cleared up on it I personally don't like that shifting down when you let up off the gas
File is a stock yukon for shifting.
Ok thanks a bunch, I'll get it loaded on the laptop tomorrow and chang to DBC, and give it a try
Ok I flaahed the Tahoe tune in "full flash", i must have missed something, it would run for 5 seconds then shut down. I reflashed my tune in, cleared set DTC codes. Drove it, rechecked codes, i am now getting a MAF code. I did disconnect the MAF for the Tahoe tun, but i did reconnect it for my tun. I'll get more information tomorrow, had to get an excaped horse reincarnated befor i headed to work
Oh i did swap the 4l80e segments out of the Tahoe tun into mine before full reflash of mine into the ECU
