See post #10 here, follow the pins from end to end: serial-port-cable-that-goes-to-v2
Hey Joe, I getting ready to start this today. I was wondering what the difference between this and the calc.maf reverse process was and whether one is better than the other?
My Scan Tool is giving me some errors with certain pids on the calc pid file. Ben From WB, Closed Loop, Dynamic Air Temp are all X.
BEN from WB {CALC.WO2BEN}
Expression:
factor = {GM.EQIVRATIO}*{EXT.WO2LAM1}
is NOT valid because:
Unknown parameter {GM.EQIVRATIO}, at position 15.
PID value cannot be determined because
the following error would occur:
Expression not valid: Unknown parameter {GM.EQIVRATIO}, at position 15.
Dynamic Air Temperature gives errors PID value cannot be determined because the following error would occur: Expression not valid: Unknown parameter {GM.DYNAIRTMP_DMA.C}, at position 21. And two others that say Expression Not Compiled.
Pid file and calc txt file
I cannot find that pid in my scan tool.
