Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 42
Thread: What options do I have for understanding the new calc.ve/maf tuning format?
  1. #21
  2. #22
    See post #10 here, follow the pins from end to end: serial-port-cable-that-goes-to-v2
  3. #23
    This is correct:
    Quote Originally Posted by Jstewy21 View Post
    RJ12 Jack
    1 <---> 1 (tip)
    2 <---> 2 (middle)
    5 <---> 3 (base)
    Is this the best way to wire direct?
  4. #24
    Jan 2009
    Hey Joe, I getting ready to start this today. I was wondering what the difference between this and the calc.maf reverse process was and whether one is better than the other?
  5. #25
    Jan 2009
    My Scan Tool is giving me some errors with certain pids on the calc pid file. Ben From WB, Closed Loop, Dynamic Air Temp are all X.
    BEN from WB {CALC.WO2BEN}
    Expression:
    factor = {GM.EQIVRATIO}*{EXT.WO2LAM1}
    is NOT valid because:
    Unknown parameter {GM.EQIVRATIO}, at position 15.
    PID value cannot be determined because
    the following error would occur:
    Expression not valid: Unknown parameter {GM.EQIVRATIO}, at position 15.
  6. #26
    Jan 2009
    Dynamic Air Temperature gives errors PID value cannot be determined because the following error would occur: Expression not valid: Unknown parameter {GM.DYNAIRTMP_DMA.C}, at position 21. And two others that say Expression Not Compiled.
  7. #27
    Expression:
    Select the pid GM.EQIVRATIO (note that it is spelled without U).
  8. #28
    Which OS do you have in the PCM...?
    Post your calc_pids.txt here.
  9. #29
    Jan 2009
    Pid file and calc txt file
  10. #30
    Jan 2009
    I cannot find that pid in my scan tool.
  1. Replies: 83
    Last Post: September 5th, 2023, 12:30 PM
  2. Understanding IAC while idle tuning
    By nonnieselman in forum Gen III V8 Specific
    Last Post: June 8th, 2018, 05:49 AM
  3. Need help with understanding MAF adjustments.
    By Redline Motorsports in forum General (Petrol, Gas, Ethanol)
    Last Post: January 18th, 2009, 03:38 PM
  4. Understanding VE and MAF
    By 98 tigershark in forum General (Petrol, Gas, Ethanol)
    Last Post: June 17th, 2008, 09:58 AM
  5. checking my understanding (2bar and maf)
    By SScarTuning in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: October 27th, 2007, 03:25 PM
