Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 42
Thread: What options do I have for understanding the new calc.ve/maf tuning format?
  1. #31
    Quote Originally Posted by Jstewy21 View Post
    I cannot find that pid in my scan tool.
    Which OS do you have in the PCM...?
    Most (if not all) LS1 OS's have GM.EQIVRATIO defined...
    on the PIDs tab, click once/twice on the Column heading Parameter (i.e. on the word itself) to sort alphabetically on this column...
    then scroll down until you see GM.EQIVRATIO.
  2. #32
    Jan 2009
    Okay I found the GM.EQIVRATIO. I realized that maybe I should connect to the PCM and see if it showed then. The Dynamic Air Temp DAT shows valid, however, Dynamic Air Temp DYNAIRTEMP_DMA is showing as invalid and won't let me click on more information.
  3. #33
    post screenshot.
  4. #34
    which OS are you using...?
  5. #35
    Jan 2009
    12212156 is the OS. Here's the screenshots.
ID:	22312   Click image for larger version.
  6. #36
    Jan 2009
    Also with this file the car stumbles when it enters PE. Are there any adjustments that need to be made to use that operating system in an older car?
  7. #37
    GM.DYNAIRTMP_DMA should be valid in 12212156...
    try going Info->Validate Pids
  8. #38
    MAF and/or VE need adjustment.
  9. #39
    Jan 2009
    I have all my pids selected and logging. Is there anything that needs to be done to the tune before starting? Does it need to be in speed density like the auto be method?
  10. #40
    Just follow the instructions in post#1 of the Calc.VET thread.
  1. Replies: 83
    Last Post: September 5th, 2023, 12:30 PM
  2. Understanding IAC while idle tuning
    By nonnieselman in forum Gen III V8 Specific
    Last Post: June 8th, 2018, 05:49 AM
  3. Need help with understanding MAF adjustments.
    By Redline Motorsports in forum General (Petrol, Gas, Ethanol)
    Last Post: January 18th, 2009, 03:38 PM
  4. Understanding VE and MAF
    By 98 tigershark in forum General (Petrol, Gas, Ethanol)
    Last Post: June 17th, 2008, 09:58 AM
  5. checking my understanding (2bar and maf)
    By SScarTuning in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: October 27th, 2007, 03:25 PM
