Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: July 2018, Beta Update #2
    Hey guys having a little trouble out in the field. I will try nd give you the facts as I know them. I sent my V2 to a friend back up in Indiana ( I know ) His work owned laptop did not allow him to Install. Got with Admin and approved. Downloaded Beta 8.2.17 and then updated the firmware. Laptop will connect to V2 but not forward to PCM. just as EXT . V2 will BBX into PCM , Datalog, Read but when trying to write get $06FF backed out and tried to write in 7.5 and 8 again no luck so loaded up on the V2 and the same Checksum error. Jesse remoted in on the original (Work ) Laptop and thought there was a clamp on the USB? So off he goes and buys a new Laptop and Installs 8.2.16 still gets no comms in pass thru . and $06ff. If I can get some help with the Checksum error we should be able to move forward using the V2 to load? Obviously time is a major factor hence him having my V2 overnighted and new laptop and all. Never seen anything like it.
    Thanks for the help today Jesse!
    Ok what ECM type is this? Based on the error there is every chance if it is a GM gas ECM the ECM already has a tune in there from another tuner that messes with how the checksum are calculated. We see this a bit and it is an easy fix.
    Would you be willing post the file up here? Or at least let us know the ECM type and the OS number of the file?
  1. Beta Test Release #3 (Apr 2018)
    Last Post: May 6th, 2018, 06:54 AM
  2. Beta Test Release #2 (Feb 2018)
    Last Post: March 19th, 2018, 05:54 PM
  3. LML Table Update Jan 2018
    By cindy@efilive in forum Duramax 2011+ LML / LGH
    Last Post: March 1st, 2018, 01:59 PM
  4. Beta Test Release #1 (Feb 2018)
    Last Post: February 12th, 2018, 06:20 PM
