Results 1 to 10 of 16
Thread: July 2018, Beta Update #2
    Default July 2018, Beta Update #2
    We strongly recommend that you do not install the beta software over the top of your production systems. It is possible that the beta test software may fail and your production system may not be recoverable. lf you conduct a tuning business, please take the necessary precautions to protect your business. EFILive recommends beta testers use a separate FlashScan V2 device (when installing the latest beta firmware) and only install the EFILive beta test software on a separate PC, laptop or virtual machine.
    Release Notes:
    Version Numbers:
    After installing this beta release you should have the following software, boot block, firmware versions installed:
    • EFILive V7 software: V7.5.21 To view the installed version, select Help->About (in the V7 Scan or Tune software).
    • EFILive V8 software: V8.2.17 To view the installed version, select Help->About (in the V8 Scan and Tune software).
    • Boot Block: V2.07.008 (Jul 04, 2018) To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
    • Firmware: V2.07.134 (Jul 06, 2018) To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
    Download here:
    Known Issues:
    Issue #1:
    Workaround:
    None.
    Issue #2:
    Workaround:
    Issue #3:
    Adding a key to the [Remote] section of a tune file is only active for the following controllers: LS1B, E38, E40, E54, E60 and E67.
    Workaround:
    None.
    Support for additional controllers will be added in a future update.
    Lifetime Member zfuller123's Avatar
    Jan 2010
    Paul would fix issue #1 please. That's been on there long enough LOL
    2005 Crew Cab Dually Duramax
    Big turbos, big injectors, big pumps, crazy heads AND a flux capacitor...
    Best run so far on street tires: 11.14 @ 128.8 mph
    Jun 2016
    I mean, V8 has only been in development for... 10 years? LOL One day....
    I'm glad you've got a sense of humor about it.
    But seriously I know it's been far too long, working my ass off to get it done.
    It'll be worth it in the end!
    Aug 2004
    first bug. When NEVER installing drivers for a v2 unit on a new machine, but you put in the license details so it is not in demo mode, and try to open up a calibration for the first time, it will Lock up the software. Then in the BACKGROUND that you can not see, will be a window box that complains about a missing driver. This is opening Efilive scan and tune. V8..
    It fails at the time when the V8 software pulls the usb for a efilive cable.
    Aug 2004
    Second bug. When reading out a 2007 lml vin number 1GCHG396171204317 flashed into it. All stock ecm. The software reads out fine. But when efi does the blend to add in the missing parts to the binary, it fails with a window saying, "cannot merge calibrations with CPU system file" , then it points to my configuration folder looking for Z00.EXT
    Jan 2010
    Anyone hit a $0371 flashing error "Transfer Suspended ($71)."?? or am I the lucky first one?
    On a CMD controller too... just for the added info. working on retrieving trace files right now to submit
    Aug 2004
    hmm that same one is coming up here on cm2350b
    Jan 2010
    Updating to the beta release fixed the issue for us. It was remote customer, he was on the last version of the beta software •EFILive V8 software: V8.2.16 instead of •EFILive V8 software: V8.2.17 so once we updated boot block, firmware and all that along with THIS software release, the problem went away and we were able to successfully flash this truck. Everything good so far!
  1. Beta Test Release #3 (Apr 2018)
    Last Post: May 6th, 2018, 05:54 AM
  2. Beta Test Release #2 (Feb 2018)
    Last Post: March 19th, 2018, 04:54 PM
  3. LML Table Update Jan 2018
    By cindy@efilive in forum Duramax 2011+ LML / LGH
    Last Post: March 1st, 2018, 12:59 PM
  4. Beta Test Release #1 (Feb 2018)
    Last Post: February 12th, 2018, 05:20 PM
