Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: ls1a error report maf HZ
  1. #11
    Mar 2013
    I have attached two screenshots. Both the Pid list and the about page
Name:	ls1a pid screenshot.jpg
ID:	22247   Click image for larger version.
Name:	ls1a pid screenshot about.jpg
  2. #12
    Aug 2013
    I'm assuming you're using a laptop...
    Hook the interface up to the OBD2 port on your vehicle.
    Turn the ignition key on, but don't start the engine.
    Click File > Select Controller... Set the correct controller type for your vehicle.
    Click the 'connect' icon in the scantool.
    Validate your Pids.
    Let us know if that helps at all.
  3. #13
    Mar 2013
    Statesman: I did what you suggested, and the situation is unchanged.
  4. #14
    Aug 2013
    There's something weird happening with either your software or your device. I looked back at your old posts and you had a similar problem tuning an E38. Try removing all the selected Pids from your list and then just select gm.maffreq and see if it validates when no other pids are selected.
  5. #15
    Mar 2013
    statesman: I did what you suggested and it worked. I unchecked all the other pids except for GM.MAFFREQ and it validated it. What do I do next?
  6. #16
    Aug 2013
    Okay, this is definitely a technical issue with your flashscan. You'll need to contact Efilive support and see if they can fix it for you.
  7. #17
    Now try adding some of the other pids back, like SAE.VSS, SAE.TP, SAE.MAP, GM.MAF
    and see what happens.
  8. #18
    Could you please try re-validating the PIDs while connected to the vehicle/controller and once that is complete, select the menu option: File->Generate error report. Save that error report and email it to me at paul@efilive.com. Include a link to this thread so I know what it is about.
  9. #19
    Mar 2013
    Blacky: Email sent
  1. LS1A Tuning
    By RADustin in forum Gen III V8 Specific
    Last Post: September 26th, 2017, 01:21 AM
  2. 98 ls1a streaming?
    By Jakes4321 in forum Purchase and Shipping
    Last Post: March 2nd, 2014, 07:47 PM
  3. Ls1 Logging error report
    By Tre-Cool in forum Gen III V8 Specific
    Last Post: December 7th, 2012, 05:49 PM
  4. MAF Error allowed question
    By LBZoom in forum Duramax LLY
    Last Post: April 26th, 2010, 01:34 AM
  5. Error Report.
    By horsehaulin in forum FlashScan V1
    Last Post: June 5th, 2008, 10:59 PM
