Results 1 to 5 of 5
Thread: E38 - B2517 - is this a bug?
    May 2012
    Default E38 - B2517 - is this a bug?
    Hey guys,
    On my E38, B2517 which is TCS throttle limiter by input speed. It looks like the table is RPM x Gear, however the input values are marked as Nm? Bit confused....
    Dec 2007
    Thats right, it limits at the torque number via throttle limiting in the respective gear at the particular RPM.
    Traction control when you dont have traction control
    May 2012
    So the table name "TCS Throttle Limiter by Input Speed" is a bit misleading then. That is where my confusion was, because I wasn't sure if I was putting in torque Nm values or speed KPH values. Cool!
    Dec 2014
    Input speed is RPM........
    May 2012
    Quote Originally Posted by Team208Motorsports View Post
    That works too - thanks!
  1. E67 B2517 TCS Throttle Limiter by Imput Speed?
    By PRAY in forum E37, E38 & E67 PFI ECM's
    Last Post: May 23rd, 2012, 12:50 PM
  2. 7.3.3 bug ?
    By Chevy366 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 14th, 2007, 10:48 AM
  3. Little bug
    Last Post: January 11th, 2006, 01:43 PM
