Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: New Bata software security unlock
    Aug 2011
    Default New Bata software security unlock
    Will this work on the complex 2018 Cummins pickup. Or only 13-17
    Sent from my Moto Z (2) using Tapatalk
    Tuning by Zack StarLite diesel
    Nov 2005
    As per the newsletter...
    Vehicles that contain a SGM (Serial Gateway Module) eg, late 2017+ will still require a means of bypassing this module in order to flash via OBD-II.
    Cindy
    Sent from my iPad using Tapatalk
    Aug 2011
    Bummer . Thanks
    Dec 2013
    There are bypass cables for the SGM. look around online.
    Mar 2015
    Any links to a cable? I've been looking for a bit now and can't find anything. I tried searching for SGM bypass cable and serial gateway module cable, nothing yet. Thanks in advance.
    Senior Member garrettg.bpd's Avatar
    Jun 2013
    Is this bad boy what you had in mind? https://zautomotive.com/product/bypass-module/
    EFILive Beta Tester
    2006 DODGE RAM 2500 4X4 Industrial Injection R1 100HP Injectors and BAG-O-PARTS, ATS Exhaust Manifold, AFE 67MM Turbo and MANIFOLD
    Jun 2013
    Round of Applause to EFIlive. Unlock works great and Flash time is awesome.
    EFILive Beta Tester
    Aug 2011
    Quote Originally Posted by garrettg.bpd View Post
    Did you do this on a 2018 ?
    Jun 2013
    No it was a 13
    EFILive Beta Tester
    Aug 2011
    Going to give it a try just ordered it.
    But my question to EFI staff is will the unlock work if if this security Bock works?
  1. Security light
    By JDPlowboy in forum Duramax LB7
    Last Post: July 15th, 2015, 11:20 AM
  2. Security Light
    By ZR2_350 in forum FlashScan V1
    Last Post: August 8th, 2010, 04:23 AM
  3. LMM security patch
    Last Post: May 16th, 2010, 11:38 AM
