Results 1 to 10 of 17
Thread: Map Data Filters in V8 Scan Tool
    Member koolky's Avatar
    Aug 2013
    Default Map Data Filters in V8 Scan Tool
    I specifically need to figure out how to apply a filter like throttle position is changing more than 5.00 % per 100 ms from V7.5 to work in V8. I've figured out how to code the the calc pids but have no clue how to factor in the 100ms timer while tracking variation in TP. I know how I would do something like this in C++ but I'm lost with Lua. Hoping I've missed something and it will be as easy as V7.5.
    Does this help?
    Aug 2013
    Can you break down the first line of code for me? I get the initiation of there variable 'tpdx' but what is dx() and what is going on within dx()?. Are frames always 1 second?
    The dx() function is provided by EFILive, this is the implementation (written in Pascal/Delphi) within the V8 software of the dx() function. It simply computes the rate of change with respect to time for a given PID value between two frames. Also known as a derivative and is usually written as dx/dt.
    Code:
    function dx(aPid: string; aFrame1,aFrame2: integer): double;
    var
      rise,run: double;
      t1,t2: double;
    begin
      // Ensure frames are in range and are ordered low->high
      CoerceAndOrder(aFrame1,aFrame2,0,FrameCount-1);
      // Get the change in PID value between the two frames.
      rise := pid(aPid,aFrame2)-pid(aPid,aFrame1);
      // Get the timestamp in ms for each frame
      t2 := time(aFrame2); // ms
      t1 := time(aFrame1); // ms
      // Calculate the elapsed ms
      run := t2-t1;
      // Compute the rate of change of the PID value per second
      if ( not IsZero(run) ) then
        Result := (rise*1000)/run  // *1000 to convert from "change per ms" to "change per second"
      else
        Result := 0;
    end;
    Note: the pid() and time() functions used in the dx() function above can be called directly from a Lua script. The pid() function always returns the metric value of a PID. Use the convertValue() function to convert from metric to other supported units. E.g. convertValue(k,"km/h","mph") would convert the value in k to mph. If k was 100, then the function would return 62.137 mph.
    Aug 2013
    How do I include a filter in a custom pid code? With the filter set as 'boolean' they don't list as pid's that can be included.
    Any calculated PID that is configured with units of "boolean" will (should) show up as selectable as a filter PID.
    Aug 2013
    Got it now. I didn't realize that I had to include them in the pid selection in order to write them into my custom pid code.
    Aug 2013
    Is there a pdf tutorial that I'm missing? The only way I can think to integrate the filter pids into the calc pid is to write the code as show here:
Name:	efilive calc pid.png
    I've set the filter pids so that they are false (zero) when the desired conditions aren't meet. That way I can multiply by each filter pid, so if one filter pid is false the equation is multiplied by zero therefore the result is zero. I haven't confirmed, but I am worried that by doing this I will have cells being filled with zeros, bringing my cell average down.
    Instead of multiplying them, you would separate the individual filters with the && operator, and drop the leading asterisk.
    You should not "embed" the filter PIDs as part of the wide band BEN calculation. Your filter PIDs should all be ANDed together in a separate "master filter" PID that return true of false depending on whether all your conditions are met or not.
    Then you simply load up your normal log file with your normal BEN factor PID logged in it and select the master filter PID by selecting it in the drop down list box at the bottom of the scan window.
    Then you apply/un-apply the master filter PID to your data by clicking on the "funnel" icon in the VCR bar. When the filter is applied all other data displays (including the maps) only include the data frames that pass the filter test.
    Filter not applied:
    Filter applied:
  1. Replies: 3
    Last Post: December 20th, 2016, 09:58 AM
  2. Map sensor problem in efi live scan tool
    By zayne0 in forum Petrol / Gas
    Last Post: October 23rd, 2014, 12:17 AM
  3. Scan tool question. No transmission data
    By 97power in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: September 5th, 2012, 03:45 PM
  4. Data Filters
    By voda1 in forum Gen III V8 Specific
    Last Post: October 6th, 2011, 06:01 AM
  5. No live data on EFI scan tool
    By Drummer in forum FlashScan V2
    Last Post: February 18th, 2008, 12:05 AM
