Results 1 to 3 of 3
Thread: Problem with some trans PIDS giving intermittent data
    Jul 2018
    Default Problem with some trans PIDS giving intermittent data
    2015 Ram 2500 CME CM2350B intermittently displaying LPRes, DESLPres, SWBSNS and Press Solenoid Duty Cycle. All remain at 0 until SWBNS drops from 18.9v to 14v and then for a split second I get data on the pres pids. SWBNS then jumps back to 18.9. Like I said this only lasts for a split second. I don
    2015 Ram 2500 6.7 Auto Maximum Steel
    Suncoast Mega Jr. 68rfe
    HPP EFILive on V2
    Stainless Diesel 468 (cast) 467.7/83/.90 and Exhaust Manifold
    GDP Torker IV Nozzles 125hp
    GDP MegaFlo S-2 with Grid Heater Relocate AirBoss 67 Plenum Cover
    Hamilton HD Push Rods and 103# Springs
    Aug 2019
    Did you ever figure that out? I get similar results with most of the Trans PIDs. I get Line pressure desired and actual just sit at 3 PSI. Then ocassionally LPD will go up and down. The graph will look like a wave. Then it'll drop down to 3 PSI again.
    There have been a couple logs where desired sits at 0 PSI and actual has what looks like a proper reading but the entire range is no where near where it should be.
    Jul 2018
    Default Trans PIDS not displaying
    Quote Originally Posted by rayacain90 View Post
    Jonathan from HPP or at least used to be before they became CTT tuning and merged with calibrated addiction, told me this was a known issue and was going to be fixed on next EFI Live update. Unfortunately that was a year ago and other than you I can
    HPP EFILive on V2
  1. Invalid trans PIDs (i.e. gm.gear) e38/t42
    By bubba68ss in forum Petrol / Gas
    Last Post: February 8th, 2016, 04:07 PM
  2. Replies: 1
    Last Post: January 29th, 2015, 11:14 AM
  3. Trans data logging today
    By dsltnr in forum Cummins 5.9L
    Last Post: January 8th, 2012, 07:35 PM
  4. Is there a trick to logging the trans data?
    By MSURacing in forum Allison 5 & 6 Speed
    Last Post: February 25th, 2009, 11:48 AM
  5. el460 trans pids
    By aaronr in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 18th, 2008, 04:55 PM
