Results 1 to 2 of 2
Thread: E38 Custom OS install with 6L80E
    Jul 2018
    Default E38 Custom OS install with 6L80E
    Let's try this again (it doesn't seem as if my first thread posted....)
    It seems that I need to install a custom OS from EFI live in order to bypass the VATS and a few other sensors and controls that I do not need for retrofitting my L9H into my classic car. However, while following the tutorial http://download.efilive.com/Tutorial...20Tutorial.pdf I am not able to read the tune from the ECM with my EFI Live tune tool (v7.5.20). It sounds like I need to be able to save the base tune file, flash the Custome OS on the ECM, then put the base tune back into the Custom OS. The tutorial shows the user (me) being able to click that green icon in order to read the ECM, but that icon is gray and un-clickable on my screen. No I am not in demo mode, and yes everything is connected correctly because I'm able to read the ECM with the Scan Tool program (the ECM's OS is 12630501-AA) and the Version 8 software is also able to communicate with my ECM/TCM.
    Let me know what your thoughts are in a simplistic way, if possible; also, if you for see any problems that I will most likely encounter, please give me a heads up
    Thanks in advance to the community I will soon be relying heavily upon!
    -Andrew
    The forum software was making sure you're not a spammer.
    I replied in your other thread: New-to-tuning-how-to-upload-the-COS-to-my-E38-T43-combo
  1. Jeep TJ Brute LS3 E38-T35 6L80e
    By RuraBrute in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: February 8th, 2018, 12:36 AM
  2. Newbie Here. Need some help on 09 5.3 / 6L80e and e38
    By DarkKnightWong in forum E37, E38 & E67 PFI ECM's
    Last Post: September 26th, 2017, 11:50 AM
  3. 6l80e E38 no vehicle speed
    By KillaKustomKables in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: February 12th, 2013, 02:21 AM
  4. e38 l92 to 6l80e in rock crawler
    By prostock3 in forum E37, E38 & E67 PFI ECM's
    Last Post: August 29th, 2012, 06:17 AM
  5. Custom O/S to control a 6L80E Trans?
    By vetteboy2k in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 2nd, 2005, 02:08 PM
