so with the red hooked up to the positive of the batery and the blue to the neg, with the terminator plug in should the wideband get warm?
I found it gets mildly warm (ouch, don't hold it between thumb/forefinger, it gets warm but not smoking hot); it gets hotter if you have running alternator (13+V) on it;Originally Posted by killaz
with fully charged battery connected (12.4+V), the LED should flash for about 20-30 seconds and then stay on steady; if it doesn't do this, then something's wrong; if it does do this, and the terminator is plugged in, the LM software should connect.
crud, i was messing with it today. Got the tester out and it red only 6 volts, also got low voltage on my HUD. Could this be my issue?
Yes, probably is, the LC-1 wants 12V or better, your battery is very very flat or failed.Originally Posted by killaz
ok so i hooked it all up and all i get is please plug in your LC-1 and power it on so is this thing blown??????? and yes it tested at 13 volts.
