Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: LS6 944 Misfire
    May 2011
    Default LS6 944 Misfire
    My car is running a bit rough so I did some logging. I see quite a bit of misfires and I'm not sure what is causing the issue. I'm trying to figure out if there if this tune related. Once in a while, I get a flashing cell when starting from cold but it goes away after a restart. I have attached two logs and the current tune, any ideas would be useful.
    LS1B_0133.efiLS1B_0134.efiLS6 944 Derron.ctz
    First, check for airleaks in the exhaust (before/after front O2 sensors), and at the intake manifold (after the MAF sensor).
    May 2011
    Checked everything out and I do have what sounds like exhaust leaks after the O2s.
    I also took a look at my VE table and looked at some recommendations you gave me some time back.
    I compared my VE table to a stock LS6 and my numbers were low in many cells. I took your recommendation of copying the VE table from a stock LS6 then added 8% form 3200 rpm to 5600 rpm. I took the car for a run and done some logging. Misfires have reduced allot.
    Take a look at the attached logs.
    Quote Originally Posted by pormgb View Post
    These leaks allow air to be pulled in in between the exhaust pulses (i.e. on each low pressure pulses).
    I'll take a look.
    May 2011
    I'll take a look.
    Thanks!!
    Misfire1.efi shows quite a few misfires counts on a few cylinders.
    Misfire.efi shows some initially, and then they go to almost none, a big improvement, what changed...?
    May 2011
    Nothing changed. I started with misfire (from cold start), stopped for gas then logged misfire1. Misfire was a longer run, I returned from the gas station with misfire. The only real difference would be the car sat in the gas station for about 10min and could have experienced heatsoak.
    I do notice that the car runs rougher when warm. On nice cool days, its a ton faster.
    Dec 2014
    Any special reason why you are running a, what we assume, stock ls6 MAF only?
    May 2011
    Quote Originally Posted by Team208Motorsports View Post
    No, I decided to use the LS6 MAF due to the integrated IAT. Is this a bad thing?
    I did some research at the time of the build, and that seemed to be the best way to go.
  1. LS6 Misfire
    By pormgb in forum Gen III V8 Specific
    Last Post: November 30th, 2014, 10:38 PM
  2. misfire with no codes, need help please!
    By mrialsm4 in forum Petrol / Gas
    Last Post: October 13th, 2010, 04:25 AM
  3. misfire problems
    By Gregs in forum Petrol / Gas
    Last Post: June 25th, 2010, 01:45 AM
  4. Fast 90 on LS6
    By Naf in forum Gen III V8 Specific
    Last Post: May 30th, 2008, 12:06 AM
  5. misfire help
    By NviouSS in forum General
    Last Post: June 3rd, 2006, 06:18 AM
