Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 43
Thread: LS6 944 Misfire
  1. #21
    May 2011
    Ah, good observation by Team208...
    is your MAF corrected...?
    looking at your log LS1B_133, it seems to me that MAF looks like it is under-reporting (i.e. MAF table needs to go up in some places).
    What areas of the MAF table seem low?
  2. #22
    Aug 2013
    Check the condition of your spark plugs and plug wires.
  3. #23
    Quote Originally Posted by pormgb View Post
    MAF Plumbing.
    Attachment 22268
    Seems ok, even tho you have no choice.
  4. #24
    May 2011
    I checked the plugs and wires, and everything looks good.
    I completed a Calc VET but the results made the car run very rough. I then tried applying only the MAF table and the car idled in the 12s AFR.
    Not sure what's going on here. I have attached my Calc VET log, and the values applied to a tune.
    I ran the car yesterday with B0120 set to 400 with the pre VET tune (iLS6 944 Derron.ctz), and the car ran quite well. Ran a short log and attached the file (LS1B_Calc VET July 28th.efi)
    Calc VET log = (LS1B_0143 orig.efi)
    Calc VET applied to original tune (July 20th (MAF+VE Applied) B0120 4000.ctz)
    Short Calc VET log collected yesterday with the original tune (LS1B_Calc VET July 28th.efi)
    Whats odd is the car ran very well with the tune that I originally posted.
  5. #25
    Aug 2013
    When you do a Calc VET, you need to be in open loop (disable your fuel trims). You also need to be in MAF only mode... your log LS1B_0143 looks like you were in blended mode.
  6. #26
    May 2011
    Quote Originally Posted by statesman View Post
    I wasn't aware of the need to disable fuel trims. I read the Calc VET tutorial and summary notes and did not see that step.
    Are fuel trims disabled by setting B4205 to something like 140 degrees disabling closed loop?
  7. #27
    ( BTW: in your tune, B3618 PE table is set to EQR 0.86 which is incorrect... set it to EQR 1.175 (i.e. 1/0.85) )
  8. #28
    If it idles that rich that something is going wrong...
  9. #29
    This log show idling at Lambda 0.982 (AFR 14.4).
    Let's compare current tune to that one...
  10. #30
    I think statesman is inferring that your front NBO2's are switching slower than usual (about 1.5/s vs 3/s)...
  1. LS6 Misfire
    By pormgb in forum Gen III V8 Specific
    Last Post: November 30th, 2014, 10:38 PM
  2. misfire with no codes, need help please!
    By mrialsm4 in forum Petrol / Gas
    Last Post: October 13th, 2010, 04:25 AM
  3. misfire problems
    By Gregs in forum Petrol / Gas
    Last Post: June 25th, 2010, 01:45 AM
  4. Fast 90 on LS6
    By Naf in forum Gen III V8 Specific
    Last Post: May 30th, 2008, 12:06 AM
  5. misfire help
    By NviouSS in forum General
    Last Post: June 3rd, 2006, 06:18 AM
