I have done everything in the tutorial to validate a pid. Is there something I am missing?
Thanks,
Glenn
Thanks,
Glenn
Right click the pid for more information, something else needs to be selected to work.
Y2K C5, M6, LS6 intake, Kooks LT headers, High flow cats, 216/224 113 LSA, 5.3 Stage II heads. STS twins. COS
What OS are you runing?
www.efialchemy.com
www.greatamericancarwar.com
I am running OS 3. I was wondering if there was something else that needed to be monitored to use this pid. I will check and get back with you.
Glenn
yes ltit and stit that match the pid. Look at its properties, it should tell you what you need.
2014 VF SV LS3 Maloo.
Can we still log RAFIG etc without the MAF ?
I'm running SD, can get all pids validated etc , but map won't show any data when I log.
Had worked for me when I tried a while back with the MAF.
Okay, got the supporting pids activated, but I made a map from another post in here. I used the RAFNP as the main page and then used ECT for the rows and columns. All I get is one square in the bottom right corner counting up from 1
Glenn
Need to log from cold startup till fully warm and have ECT selected.
LABELS RAFPN Grams/s RAFPN (Cell Count)
ECT In_Gear Park/Neutral
-40
-28
-16
-4
8
20
32
44
56
68
80
92
104
116
128
140
This is what I have, do I only need ECT in the rows and forget about the columns?
Whatever table you are trying to adjust in tuning needs to be fully represented in the scan tool. I normally copy from tuning to scan. Mind the units so you don't adust grams by pounds etc.
The example I gave earlier was for RAFPN, sorry if that was misleading.
