Results 1 to 4 of 4
Thread: 2-3 Cut loose on LS3/4L70E setup
    Default 2-3 Cut loose on LS3/4L70E setup
    So we have a GM 480HP LS3 Crate that a customer wanted to use he ordered the engine and Trans it has E38 PCM and T42 PCM. I am having trouble with cut loose issues under heavy throttle between shifts, could you check this over and provide some pointers on this setup.
    Try adding Torque Reduction in table D2104 (and maybe also D1104, D3104 if necessary).
    Im used to completely removing all Torque reduction from 24X stuff, how much would you suggest to add and only on the higher RPM's?
    Try adding say 25% and see how much difference it makes, you can then tailor it from there.
  1. GMPP LS3 (E38) w/ 4L70E in square body 4x4
    By TurboCamaro in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 11th, 2018, 11:08 AM
  2. Will I loose tune if battery dies
    By stogen in forum AutoCal
    Last Post: February 15th, 2012, 01:14 PM
  3. If you remove the Tq Management, do you loose traction control?
    By blueblazer5_3 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 21st, 2007, 12:39 PM
  4. Loose converter/shifting.
    By VHR in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 5th, 2007, 10:46 AM
  5. SLP 85mm MAF resistor, cut or not cut?
    By queso in forum General (Petrol, Gas, Ethanol)
    Last Post: October 9th, 2007, 12:50 PM
