Results 1 to 5 of 5
Thread: Topkick 5sp to 6sp conversion
    Jan 2009
    Default Topkick 5sp to 6sp conversion
    Is it possible to update the software in the TCM to enable 6th gear? From what I am reading it is a simple GM flash, do we have the ability to do that update with EFIlive (way back last time I looked I dont think full flashing was an option). And if so does anyone have a 2008 TCM file that would work.
    Thanks in advance.
    Mitch
    Dec 2005
    If you get me a VIN# I can get a A50 File from TIS and email it over, I have done a few of them, but its been a few years
    www.mscservices.net
    Aug 2021
    GMC-2002-Dmax hey any chance you could still do that? I worked for gm for a few years but don
    Dec 2005
    It required a TECH2 or MDI or Mongoose Cable with a TIS Subscription, which I had at the time.
    I would have to see if I can track down the actual procedure, as it has been many years since I did one.
    Give me a few days to try and track down what I did.............it was over 8 or so years ago I did one of these
    www.mscservices.net
    Quote Originally Posted by Mitco39 View Post
    Thanks in advance.
    Mitch
    Mitch what you want is possible if it is an medium duty 06-07 5-speed, but not practical to try and do it with your TCM. It requires a TCM swap, a service we provide. Your TCM cannot be converted using efilive alone. For that reason, we do these in batches. IIRC the cost is $295 for the factory 08 file, or $395 for the refined shift/TC schedule, which adds some comfort from early TC lockup, and leaves 5th and 6th gear in a better rpm range than the factory file.
    Custom Tuning Services
  1. 2009 topkick wont start
    By hampy in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 23rd, 2015, 03:21 PM
  2. I need a stock file for i4 p12 2004 colorado 5sp
    By Garth@undercover in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: June 19th, 2013, 08:34 AM
  3. 6sp Allison
    By jay p in forum FlashScan V2 BB Logging
    Last Post: March 24th, 2008, 01:43 PM
  4. 5sp Allison TCM Scan issue
    By Cougar281 in forum FlashScan V2 BB Logging
    Last Post: February 21st, 2008, 04:16 PM
  5. 5sp ally programming
    By dynarex in forum General (Diesel)
    Last Post: November 19th, 2007, 02:07 PM
