Results 1 to 3 of 3
Thread: False knock root cause on 0411 pcm
    Jun 2013
    Default False knock root cause on 0411 pcm
    I just did a 4l80e swap on my 2001 suburban 1500/5.3 so i don't have to keep living in fear of the 60e losing the 34 clutch packs again. I full flashed to a 2002 os and did a segment swap. Im getting very slight knock in low load areas. Im not too concerned about the knock but i am wondering if the false knock problems with my 2001 pcm would be fixed with the 2002 os upgrade or is the problem hardware related. I also noticed that between 2001 and 2002 the 5.3 seems to have exactly the same engine but different spark and ve tables. I am getting far less knock with the stock 2002 tune than i ever did with the earlier os and tune with less timing. Seems like the 2002 os fixed it.
    On my 2000 i did a 2002 (12212156 OS) full flash and i never had any of the false knock show up after that. The 2000 was horrible. I even copied the 2000 Spark tables into the 2002 tune and didnt show any knock where it use to.
    Jun 2013
    I would say the false knock problem is the software then...
  1. Knock knock, False knock? LS3 mutant in C5 car LS1 pcm
    By BHC5 in forum Gen III V8 Specific
    Last Post: July 6th, 2017, 09:14 AM
  2. Possible False Knock
    By Kevin Doe in forum General (Petrol, Gas, Ethanol)
    Last Post: May 13th, 2009, 01:32 AM
  3. What to do when you get false knock???
    Last Post: May 19th, 2008, 02:30 PM
  4. False Knock?
    By sean3393 in forum Vortec V6/V8 Specific
    Last Post: February 5th, 2008, 11:36 AM
  5. False Knock?
    By oztracktuning in forum General (Petrol, Gas, Ethanol)
    Last Post: April 9th, 2006, 02:27 PM
