Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Auto VE Twin Turbo 5.3
  1. #11
    i.e. not CALC.BEN_LC11.
  2. #12
    Dec 2014
    Select the either one of the following sets of pids:
    - EXT.WO2LAM1, GM.EQIVRATIO, CALC.WO2BEN;
    - EXT.WO2AFR1, GM.AFR, CALC.BEN1.
    I'll do that and I'll let you know tomorrow what happens. Thanks Joe
  3. #13
    Dec 2014
    Joe, we finally made a step in the right direction. The ben from WB is an average of .8064. I'm not sure what I have changed but for some reason on the ben map it is only taking data on the far right side. After filtering I get an average of 0.0. I'll attach some pictures. I ran into this a while back and figured out I was copying and pasting labels wrong but I'm not sure what is causing it this time. I'm very happy with what you recommended.
ID:	22284   Click image for larger version.
ID:	22285   Click image for larger version.
  4. #14
    Post your new log file.
  5. #15
    Dec 2014
    Joe, attached is my current tune and datalog from yesterday. As always, thanks for the help. I appreciate it.
  6. #16
    Quote Originally Posted by C450 View Post
    Can you do something to make combustion go lean, WB should then show lambda greater than 1.00.
    In scantool:
    - on PIDs tab, on MAP pid, go rightclick->Metric.
    - on Maps tab, in map properties, on the Column tab, click Show Units, then select MAP.kPa for the column pid.
    Post some screenshots ( hint: try getgreenshot.org to capture screenshots ).
  7. #17
    May 2008
    where do u live? r u using the v2?
  1. help with twin turbo tune
    By Cubicylndr16 in forum Gen III V8 Specific
    Last Post: June 16th, 2016, 11:47 AM
  2. 5.3 twin turbo
    By danny68ss in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: January 17th, 2015, 03:48 PM
  3. Twin Turbo Tuning
    By WisconsinHick1 in forum General (Diesel)
    Last Post: May 12th, 2013, 06:17 PM
  4. twin turbo's
    By limited cv8r in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: July 15th, 2007, 03:22 AM
  5. STS Twin Turbo
    By purrvert in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: December 20th, 2006, 09:25 AM
