Results 1 to 10 of 13
Thread: New to Efi Live
    Nov 2016
    Default New to Efi Live
    hi guys i am new to efi live as the title states, i have a 78 camaro with a ls1 and a 4l60e tranny, the car has run great for 4 years now and has just started some surging issue while acceleration, i have logged a quick little run and was wondering if i post the tune and log if some one could look at and maybe pin point the issue for me. any help would be appreciated
    Looks like MAF is under-reporting.
    Were you running closed loop trimming...?
    Nov 2016
    sorry joe i was away for a few days, but like i said i am new to this i bought efi live to log what was going with the car, the tune was done by some one else so i am not sure if it runs in close loop or not... i wish i could tell you more, i am reading and learning about it but is going to take awhile, how does the tune look by the way??thanks
    May 2008
    if the car ran good for four years I wouldn't think it would be the tune. check for vacuum leaks behind the maf also you need to log some more pids also look for misfires
    +1 on what GMTECH4 said.
    Your MAF sensor might be dirty (what air filter do you have...?)
    Nov 2016
    what pids do you recommend i use , i just used what was set up in efi live, and i am using a spectra air filter, again thanks for the help and patience
    Quote Originally Posted by cvhu View Post
    If this filter requires applying oil to the filter element, then this oil can contaminate the MAF sensor... you have to minimize oiling the element... and you have to clean the MAF sensor frequently.
    Log these pids:
    SAE.MAP
    SAE.MAF
    SAE.RPM
    SAE.TP
    SAE.LONGFT1
    SAE.LONGFT2
    GM.HO2S11
    GM.HO2S21
    GM.IBPW1
    GM.IBPW2
    GM.MAFFREQ
    GM.EQIVRATIO
    GM.MFTOTAL
    GM.KR
    SAE.SPARKADV
    SAE.IAT
    SAE.ECT
    CALC.CYLAIR
    CALC.INJDC1
    CALC.INJDC2
    remove SAE.O2S11, SAE.O2S21.
    Nov 2016
    thanks joe i will try those pids, also i dont use oils on my filter
    Clean the MAF anyway (use CRC MAF cleaner) and see what it logs.
  1. Replies: 16
    Last Post: June 14th, 2016, 03:24 AM
  2. Replies: 10
    Last Post: December 26th, 2011, 07:44 PM
  3. Is EFI Live right for me?
    By jon6.0 in forum General
    Last Post: May 21st, 2011, 09:18 AM
  4. Efi live class at efi university
    By Robbie The Wrench in forum General (Petrol, Gas, Ethanol)
    Last Post: September 1st, 2008, 01:25 PM
  5. new to efi live
    By ilov2xlr8 in forum Gen III V8 Specific
    Last Post: March 28th, 2008, 02:45 PM
