Results 1 to 4 of 4
Thread: fuel status 58
    Jul 2018
    Default fuel status 58
    I have a log from a customer where boost drops out and goes from fuel status 7 to 58. Can anyone point me in the right direction on fuel status 58?
    Oct 2014
    What else is going on? What rpm, what boost, what's the fueling drop down to?
    Jan 2016
    What is coolant temp in the log?
    Fueling State
    58 – EWP (Engine Warmup Protection)
    Disables accelerator pedal torque request in order to give time for oil pressure to build up and thus prevent damage to the engine.
    Time limit is based on coolant temp, colder the coolant the longer the delay
    Lifetime Member comnrailpwr's Avatar
    Jun 2011
    I'm having the same problem. The only thing has changed on my truck was the ECM. Now this issue. I repurpose my coolant temperature sensor for oil temperature as I don't run any coolant. Temperature on my log was 105 degrees. I got it up to 120 degrees and nothing changed either. I believe there's still some limiters behind the scenes that are not knocked out for the CMB ECM. I ran into the same similar issue last year except with timing being Limited. My trucks a little different as it doesn't use the standard sensors and a lot of them are repurposed for other things. but there's definitely some limiter still in these guys. Anyone have any ideas or operating systems I think my cure the problem? Tried 409, 202, 602 all in csp5 format with no luck. This is a manual transmission stand alone setup with heavy modifications if it matters.
    Fuel is being Limited to 51mm3 max
  1. Cummins Fueling Status and Timins Status
    By comnrailpwr in forum Cummins 5.9L
    Last Post: October 21st, 2023, 01:58 PM
  2. What does ol-failed means on the fuel system status ????
    By 400ss in forum Gen III V8 Specific
    Last Post: January 13th, 2013, 07:45 PM
  3. fueling status???
    By relentless addiction in forum General (Petrol, Gas, Ethanol)
    Last Post: May 9th, 2012, 11:23 AM
  4. V2 status
    By minytrker in forum FlashScan V2
    Last Post: November 19th, 2006, 01:21 PM
  5. Order status
    By hpcubed in forum General (Petrol, Gas, Ethanol)
    Last Post: February 12th, 2005, 01:36 PM
