Results 1 to 5 of 5
Thread: E39A VATS Patch
    Jan 2014
    Default E39A VATS Patch
    Hello Guys,
    We are working on a custom chassis car and we would like to know if it's possible a VATS patch on the E39A ecm.
    Thanks!
    I don't an E39A file handy, but I checked the E39 one I have and the VATS patch is available. You'd need to open the tune with your V2 plugged in to see the VATS patch folder.
    2013 Sonic RS Manual - 1.4L I4T E78, starting the mods
    The patch is needed to be done on a per OS basis, if yours does not have it just let support know what OS and we can look in to it.
    Need official EFILive help, please go here.
    For tuning support please post your questions on this forum (or other auto forums).
    Sorry if I don't respond to your PM, don't take it personal.
    Oct 2019
    I have an E39A that I'd like to disable the VATS on.
    The OS is 12654753
    This is my first post, I am a TAFE lecturer looking to run these engines on a stand after apprentices strip and rebuild them.
    Thanks in advance
    The patch is done for that OS, you do need to have your V2 plugged in to the USB port to see it.
    I've attached the latest .calz file for that OS which I just tested and it has the VATS patch show up.
    If you want to save it in to the folder below then you should be set to go.
    C:\Program Files (x86)\EFILive\V7.5\Calibrations\E39
  1. E92 VATS patch
    By Brads_rs in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: July 2nd, 2018, 12:08 AM
  2. E98 Vats PAtch
    By SkyMadness in forum E98 2014+ Diesel ECM
    Last Post: June 12th, 2017, 10:01 AM
  3. E80 VATS Patch
    By jrz in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: March 13th, 2017, 12:01 PM
  4. Vats Patch
    By derkscustomcars in forum E37, E38 & E67 PFI ECM's
    Last Post: October 22nd, 2016, 05:42 AM
  5. what is vats patch and how do i use it
    By 400ss in forum Gen IV V8 Specific
    Last Post: July 5th, 2012, 08:10 PM
