Results 1 to 4 of 4
Thread: E78 Boost Sensor Recalibration
    Jan 2014
    Default E78 Boost Sensor Recalibration
    Hello Guys,
    We would like to install a 3 bar boost sensor, is it possible to recalibrate it?
    Thanks!
    Yes, B2101 and B2103 should allow you to modify the MAP sensor for a 3Bar MAP. FWIW, the E78 is used on the 1.4 turbo engine in the Sonic, Cruze (1st gen), and Trax.
    Jan 2014
    Hello,
    Regarding the scaler, what unit is the value b2101, e.g. KPa/Volt?
    Also there is a MAP on the intake manifold and a boost sensor on the intercooler pipe, Could I recalibrate the boost sensor?
    Thanks!
    Quote Originally Posted by SkyMadness View Post
    Hello,
    Thanks!
    The unit info is specified on the parameter definition, but the units are scaler/kPa/PSI.
    I dont know about the boost sensor in the intercooler pipe, I only see a Supercharger Inlet Pressure sensor so that wouldnt be applicable to this Turbo application.
  1. Speedometer recalibration
    By Telco in forum Gen III V8 Specific
    Last Post: November 9th, 2013, 05:19 PM
  2. Speedo recalibration
    By LIL DAVE in forum Tips and tricks
    Last Post: February 15th, 2011, 08:42 PM
  3. Boost with a 1bar map sensor
    By franckrem in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: April 26th, 2010, 04:52 PM
  4. creating a map formaf recalibration
    By ahall1 in forum General (Petrol, Gas, Ethanol)
    Last Post: February 4th, 2006, 03:30 PM
