Results 1 to 8 of 8
Thread: Cummins User Guides
    Diesel Forum Support Site Admin
    Nov 2005
    Default Cummins User Guides
    There are a range of documents to assist users tuning the 6.7L Cummins.
    Cummins 2010-2018 Quick Start will assist new users to EFILive in setting up their FlashScan, reading, editing, flashing and logging their truck.
    Cummins 6p7L CM2100A CSP5 User Guide provides step by step instructions on upgrading to CSP5, switchable tuning on the fly.
    Cummins 6p7L CM2200 CSP5 User Guide provides step by step instructions on upgrading to CSP5, switchable tuning on the fly.
    Cummins 6p7L CM2350B CSP5 User Guide provides step by step instructions on upgrading to CSP5, switchable tuning on the fly.
    Cummins BootRSA Patch User Guide provides an overview of the RSA digital signature and ways to overcome these restrictions.
    Cummins ECM reference notes assists users with Checksum information, CVN info, VIN issues and debunks a few ECM myths.
    Documentation can also be found in EFILive Scan and Tune Software by selecting Help -> Documents
    The EFILive Development Team
    Nov 2005
    In June 2018, EFILive implemented a method that no longer requires third party methods of removing the Digital Signature via OEM 3 Plug Connector for CM2350B controllers. The EFILive ECM flash process now manages this function through the OBD-II port.
    Bench flashing for CM2100 and CM2200 controllers also use this process eliminating the previously implemented BootRSA Patch file process.
    In vehicle flashing for CM2100 and CM2200 controllers still requires the BootRSA Patch file process to remove the digital signature. Please refer to the Cummins Boot RSA Patch User Guide.
    NOTE: The ECM must be fully operational and not in boot mode as a result of a failed flash (error $0340) or forced boot mode. Where the ECM is in boot mode, the unlock process is bypassed and two-step flash process is required to remove the digital signature.
    1. Recover the ECM by flashing a stock tune to restore the ECM to operational mode.
    2. Flash the ECM to remove the digital signature.
    Documentation in the links above have been updated to include these changes.
    Cindy
    Aug 2018
    Can someone please help me with this I have a 2017 ram cm2350b and I bought efi live for my use and several others and I need a install for dummies I have downloaded the v8.2.18 for beta test trial set up my v2 and being the first time using it makes it hard enough but the unlock process through the obd2 but the gateway module I just want to be sure that I’m doing this 100percent correct I really don’t want to blank out my ecm I have read the artical about the 2010-18 10 times and it jumps back and forth from the 2100 to 2350b so much I don’t want to mess this up I have the understanding that I might need a gateway bypass that’s fine how do I know if my truck needs it can I fine out without putting my truck to sleep
    Nov 2005
    Quote Originally Posted by Codyjones View Post
    If you have a CM2350B, and have updated your software to V8.2.18 and have updated your firmware to V2.07.135 you do not need this document.
    You only need this document if you have either a CM2100 or CM2200 and want to flash in-vehicle, or CM2350B if you've chosen not to update your software and firmware.
    The flash process will manage the unlock process.
    Cindy
    The gateway module will block flash attempts, nothing will happen to the ECM the software will just say it could not put the ECM in to programming mode if your truck has one.
    Aug 2018
    Thank you for the quick response sorry these questions might seem dumb to you guys but I work at a semi dealership and install Cummins software almost daily and granted it is Cummins software there are still unspoken rules and steps to fallow and I have had to manually input every parameter to revive a ecm from being blanked out but without access to my true ecm parameters might make me more nervous than most just wish there was a tuning for dummies cm2350b unlock addition I
    No it is good to be cautious, Cummins ECM's do like to just give up working for no particular reason.
    Aug 2018
    Cindy
    thank you guys are with your quick response and knowledge I have been a part of many forms but so far I know its only been several days but this is the best I'm glad this form is here and I'm ready to help others when I have a better grasp on the programming I look in the future to try and help as many ppl as I can for the fact being that I have been there
  1. E98 User Guides
    By cindy@efilive in forum E98 2014+ Diesel ECM
    Last Post: March 28th, 2018, 01:35 PM
  2. Cummins User Guides
    By cindy@efilive in forum Cummins 5.9L
    Last Post: March 23rd, 2016, 11:39 AM
  3. EFILive for Dummies - How to guides
    By cindy@efilive in forum Cummins 6.7L
    Last Post: February 19th, 2016, 10:32 AM
  4. EFILive for Dummies - How to guides
    By GMPX in forum Cummins 5.9L
    Last Post: August 13th, 2013, 12:24 PM
  5. Can we get some Allison guides or tutorials?
    By Whippled 496 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 17th, 2006, 11:31 AM
