Results 1 to 10 of 13
Thread: logging with serial plx wide band / e40 ecm cos 2 bar system
    Jul 2018
    Default logging with serial plx wide band / e40 ecm cos 2 bar system
    Hi , very new to efi live plenty of reading to do. I have purchased the new plx gen 4 wide band and will be doing the internal mod https://forum.efilive.com/showthread...R-Serial/page4 and set up my pids but I cannot find the ben pid for the wide band ( plx serial ) I am going to use please help. As this is my first post I have
    attached my current pid selection , it has a x next to it let me know what you think thanks kindly.
    The serial comms pids are these:
    - EXT.WO2LAM1
    - EXT.WO2EQR1
    - EXT.WO2AFR1
    - EXT.WO2ST1
    - CALC.BEN1
    Jul 2018
    thanks Joecar.
    Jul 2018
    - EXT.WO2LAM1
    - EXT.WO2EQR1
    - EXT.WO2AFR1
    - EXT.WO2ST1
    - CALC.BEN1
    Hi joe , I want to use the sae.lambda and EXT.w02lambda1 pid but I don't see the CALC. ben pid for lambda ?
    Question: which of these pids does your PCM support: SAE.LAMBDA or GM.EQIVRATIO...?
    Log each one and post the log.
    Jul 2018
    Hi Joe , im trying to validate my pids (22) of them but the GM.EQIVRATIO,GM.IBPW1,GM.IBPW2,AND GM.DYNCYLAIR PIDS WILL NOT VALIDATE they have an x next to them ?
    Jul 2018
    did a log and believe it logs the sae. lambda which is the EQ ratio . this log was mostly at idle. im using the laptop and
    V2 . Also when you log through BBL how do you look at the log with V7.5 scan
    You will need the pid CALC.WO2BEN from this calc_pids.txt.
    ( if your calc_pids.txt is original/un-modified, you can just copy the attached calc_pids.txt to the User Configuration folder )
    edit:
    in the attached cacl_pids.txt you will have to edit CLC-00-110 to use SAE.LAMBDA instead of GM.EQIVRATIO...
    i.e. replace this:
    Code:
    *CLC-00-110
    factor             0.5           1.5       .4  "{GM.EQIVRATIO}*{EXT.WO2LAM1}"
    with this:
    Code:
    *CLC-00-110
    factor             0.5           1.5       .4  "{EXT.WO2LAM1}/{SAE.LAMBDA}"
    Ok, this is one of those special cases...
    if SAE.LAMBDA behaves like EQR, then use SAE.LAMBDA in place of GM.EQIVRATIO...
    i.e. like this:
    Code:
    *CLC-00-110
    factor             0.5           1.5       .4  "{SAE.LAMBDA}*{EXT.WO2LAM1}"
    ( be sure to multiply by it )
    Jul 2018
    Joe , in my user config folder I have two calc_pids.txt documents . I may of copied one from the forum and placed it in my folder .With
    the calc_pids.txt e40 file. Do you only need the one and make changes to it ? I have attached both let me know which one to use thanks.
  1. Wide Band O2 to ECM unused EGR
    By kirklanc in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: December 13th, 2018, 05:50 AM
  2. V2 LC-1 serial wide band will not read
    By strokerstang86 in forum External A/D inputs
    Last Post: May 12th, 2017, 10:08 AM
  3. Newb Setting up serial Wide band
    By HellKnightHicks in forum General
    Last Post: January 16th, 2013, 11:30 AM
  4. Installing an AEM Wide Band 02 and logging afr
    By johnmaster in forum Gen III V8 Specific
    Last Post: July 4th, 2011, 09:00 AM
  5. 2 BAR COS on E40 LS2
    By MadMaxHSV in forum Custom Operating Systems
    Last Post: July 21st, 2010, 07:53 AM
Tags for this Thread
