Results 1 to 7 of 7
Thread: Tuning CUSTOM E40 ECM boost VE table with lesser injectors!
    Jul 2018
    Default Tuning CUSTOM E40 ECM boost VE table with lesser injectors!
    Hi, very new to efilive, have purchased the v2 unit and have been reading the forum pro furiously
    Months now .Trying to gain enough exp and knowledge to make my own adjustments :Eyecrazy. My tune
    Was done professionally several years ago made over 1000 rwhp S /C with the suited injectors at that hp. Currently now the vehicle is de- tuned with a s/c air intake restriction and smaller injectors ,maffles,open loop Sd tune .Now reading efilive posts and looking at most tune files on forum I notice that VE tables usually increase air as map and rpm increase . Looking at my table I note that at the higher map /rpm areas my table values
    Become lesser. Would this be due to having smaller injectors that would run out at higher boost levels?
    Can you trick the ECM by scaling down the V/E table when you have not enough injector flow at high Rpm.
    My objective would be to change injectors , re- do VE , timing and so on
    Last edited by joecar; August 20th, 2018 at 05:10 AM. Reason: corrected spelling of titile (allows searching to work)
    You should just re-scale the injector tables including IFR, pulsewidth, voltage offsets and if the VE is close, it shouldn't require much more than a quick touch-up of the VE tables.
    Jul 2018
    Hi Erik, thanks for the response . I am very new to efi -live slowly learning through the forum and hopefully understanding enough
    to have the confidence in applying what I learn to my own vehicle. My engine is highly modified running a vortech v7 SC. It was
    tuned by one of the best that was at the forefront when efilive started. The ecm is an e40 with the boost table , originally it was tuned
    with the 1000cc rc injectors with a driver ( for max HP ) but being a street car the most efficient injectors at the time for street duties were the Siemens Mototron 60lb/h and that's what is currently being used. Currently I have an air intake restriction prior to the SC
    air intake due to I think the injector is not large enough. If removed it has delivered 20-22 psi with the correct injectors . hopefully one
    day I wish to put bigger injectors and remove the restriction and re- map the required tables . I believe im running OLSD tune without the maf .
    your response is a little confusing to me , the car runs and idles quite well I'm trying to get my head around my tune esp the air tables .
    Do you know these things:
    - what is the flowrate of your new injectors (and at what pressure are they rated...?)...?
    - what is your rail pressure (measure with manifold reference hose removed)...?
    If you put the correct injector flow rate into table B4001, then your previously tuned VE table should still be quite close, as Erik said.
    Jul 2018
    Hi Joe , I am slowly understanding this tunning ( efilive ) as I progress and hopefully understand I become more excited. I am still
    waiting for my plx W/B serial conversion with the TTL converter board to arrive its been about 4weeks and still waiting for delivery . I cant wait to have all my pids logging correctly and then making the correct changes to my tune .
    Firstly I would like to really commend you on the support you provide to all that are new to this forum , without your help we prob
    would be screwed . At the moment I'm screening my current tune and coming to terms with the table values ( why and how ) .
    - what is your rail pressure (measure with manifold reference hose removed)...? It is prox 58psi ( but does flexuate a tad )
    what is the flowrate of your new injectors (and at what pressure are they rated...?)...? I have not decided on injectors but I would need
    injectors suited to around 1000 rwhp . Would you recommend any with all the data and have excellent idle characteristics?
    I have attached the data from the siemens deka 60lb/h that is currently in my tune.
    Quote Originally Posted by Mr teabags View Post
    would be screwed .
    Here is some reading that will hopefully explain how the GM PCM's determine fuel/air: https://forum.efilive.com/showthread...-Summary-Notes
    Note that your E40 ECM is GM's transition from the LS1 P01 (part # 0411) PCM and the LS3 E38 ECM... so it has features/tables/pids from each.
    The GM Service Manual states that 58 +/-1 psi is acceptable.
    Try to get injectors for which there is established data, not just the flowrate, but also the boundary condition data (like small pulse flow).
    I believe the Siemens Deka 60 lb/hr have established data, there is a data sheet floating around somewhere.
    Huge injectors will idle just fine if the small/minimum pulse flow data (and a few other parameters) is all correct (sometimes may have to run a lesser rail pressure (so scale the IFR table to this rail pressure).
    Jul 2018
    Hi Eric , I just understood what this response meant. I now have more reading to absorb, obviously with an over-temp brain.
  1. tunning advice and help for bigger injectors in 5.9
    By Scarface in forum Cummins 5.9L
    Last Post: June 20th, 2017, 03:41 AM
  2. tunning for bigger injectors
    By gigabrock in forum Duramax LB7
    Last Post: February 18th, 2015, 04:06 PM
  3. Tunning for 160# Bosch injectors
    By TransAm-Z in forum General (Petrol, Gas, Ethanol)
    Last Post: January 28th, 2015, 10:21 AM
  4. E40 Boost VE tablevalues disappear after flash...
    By rubbersidedown in forum Custom Operating Systems
    Last Post: March 18th, 2011, 01:39 PM
  5. OLFA table vs. Custom OS A0008 table
