Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: LS1B Operating System Upgrade Help
    Jun 2018
    Default LS1B Operating System Upgrade Help
    I did try to flash over the factory Chevy Express Van tune with no changes other than vats disabled and it still would not start.
    Dec 2014
    You can’t do that. The conversion is 24x based not vortec 5.7 low res. An 02 express still ran a 5.7 vortec.
    I'm not familiar on what the trucks/van run, but Team208MS has a point, incompatible CKP signals... this will most likely be the reason for no start/run.
    Dec 2014
    You have to modify a ls based tune for the conversion. Start with a truck 2156 5.3 and copy over info from there.
    Agreed with Team208Motorsports and late to the party here.
    Looking at the TorqHeads 24x conversion kit, it runs the regular 24x/1x LS1 style setup not the low res the Express 5.7L/350 SBC uses. You need to use whatever base file it came with (Truck, F-Body, Vette) to keep the plug n play wiring. I'd guess F-Body or Truck, so grab a truck 12212156 OS and try that. Either 5.3 or 6L with appropriate trans segment and full flash it.
    Joe, the 02 Express Vans have a 5.7L SBC and the universal OS 12212156 which allows anyone with a SBC to easily run a LS1 512kb PCM and COS5. I.E. 96-00 Tahoe/Suburbans / C/K trucks that came with the Vortec Black Box PCM.
    Jun 2018
    I will execute these steps this weekend. Thank you all so much for the amazing knowledge and help!
    Mar 2010
    Quote Originally Posted by fleshe View Post
    fleshe,
    What did you end up using? I have a similar situation and need some help also. I did make a post. Do you have a tune file I could try?
    01Z06, A4, Huron Speed Twin 67/66's on a 347
    Jun 2018
    Quote Originally Posted by RonnieW View Post
    fleshe,
    PM me your email and I'll send you the tune file.
    Sent from my Pixel 3 XL using Tapatalk
  9. #19
    Mar 2010
    PM sent, maybe twice. Thanks for the quick reply!
  1. Different Operating System ?
    By 1stGlance in forum General
    Last Post: August 15th, 2012, 08:22 AM
  2. change the operating system
    By cainer70 in forum General (Diesel)
    Last Post: March 30th, 2010, 02:19 AM
  3. 02 operating system?
    By THEFERMANATOR in forum Allison 5 & 6 Speed
    Last Post: October 25th, 2009, 12:58 PM
  4. Going from 00 to 02 operating system
    By lastcall190 in forum Gen III V8 Specific
    Last Post: November 12th, 2007, 04:50 PM
  5. operating system
    By ls1transam346 in forum Gen III V8 Specific
    Last Post: February 22nd, 2007, 11:49 AM
