Hi , Im following the tutorial on installing a SD card but the V2 Unit Looses power On lcd screen and I loose
communication . If I remove the sd card it will power back up . SD card im using is 16gb verbatim
All sorted , the sd card I purchased was not compatible, replaced all good
Just out of curiosity, what was the SD card that's compatible btw? I plan on buying a new SD card as well.
I strongly suggest these fat burners for men because they worked for me.
I don't know what SD card Mr teabags used.
( I know SanDisk is ok )
Supported SD Card formats, and SD card configuration instructions are documented here.
https://support.efilive.com/kb_artic...6425-AKLC-5907
Cheers
Cindy
Sorry guys the sandisk 16gb memory card works well
