Results 1 to 6 of 6
Thread: Data Logging Bug with Scan Tool in V8
    Jan 2009
    Default Data Logging Bug with Scan Tool in V8
    I am experiencing a weird issue with the Scan Tool in V8 that I've had ever since using it. I was wondering if someone can possibly assist. I took a video of what's going on because I figured it'd be hard to explain. Basically the live data does not show up right away (or at all) until I change the properties of the map I'm on. The video link is below. Has anyone else experienced this? I don't know if I can scan my '12 Regal GS with V7 as the PID list is much different and I can't scan nearly as many channels (unless I'm missing something) as I can with V8. Any help would be much appreciated. I've had this issue on two different HP laptops running Windows 10. I'm lost. Thanks.
    I can confirm/reproduce the same problem you have reported. It will be addressed in the next update.
    Thanks for taking the time to make the video and upload it - makes it so much easier to reproduce and track down the problem.
    Jan 2009
    Much appreciation for the response. As far as you know, there is really no workaround? Do you believe it might be the systems I'm using or like a display setting? Not a huge deal if the update will address it, but I'm just curious. Any idea when the next public release will be coming?
    Thanks again.
    Brad
    Quote Originally Posted by edwardzracing View Post
    Thanks again.
    Brad
    No unfortunately there is no workaround. After investigating this issue, turns out the code that updates the maps in real-time was disabled* some time ago due to changes made to the way PID aggregates were handled for the charts (i.e. the min/max/avg/stddev values displayed when you select a range). In fact selecting (or deselecting) a range in the charts will cause the maps to re-populate with the current data. So even though they are not updating in real time you can still see the resulting map once you stop logging by selecting and then de-selecting a range of data in the charts (or simply left-clicking in the chart area). You just can't do that while the data is being logged.
    * It was disabled when the code that handles the chart aggregates and the code that handled the map data was consolidated into a single routine. That routine used to be updated in real-time. However, computing the stddev in real time was too time-consuming and so was reduced to computing the aggregate data only after a selection was made. That had the unfortunate side effect of knocking out the maps' real-time updates as well.
    The next update (the first one with the problem resolved) will be a beta update and should be available some time later next week. It will be posted in this forum: https://forum.efilive.com/forumdispl...tallation-Help
    Oct 2005
    I had the same experience today. I can confirm that the Beta update fixed it.
    2017 Camaro SS, 2014 Ram 2500 4x4 Cummins 6.7L, 2004 Chevy Avalanche Z71 4̶X̶4̶(now 2WD), 5870lb race weight, 10.93@ 124, Twin TVS1900s, Twin Throttle, 429 LSX, 4L80E, custom 14 bolt rear, V2, R̶o̶a̶d̶R̶u̶n̶n̶e̶r̶(dead), COS3......
    Gettin' the Groceries
    DrX, thanks for confirming.
  1. Map Data Filters in V8 Scan Tool
    By koolky in forum General
    Last Post: July 12th, 2018, 12:38 PM
  2. LML scan tool/logging
    By DURAtotheMAX in forum Duramax 2011+ LML / LGH
    Last Post: March 18th, 2016, 11:12 AM
  3. Scan tool question. No transmission data
    By 97power in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: September 5th, 2012, 03:45 PM
  4. No live data on EFI scan tool
    By Drummer in forum FlashScan V2
    Last Post: February 18th, 2008, 12:05 AM
  5. Bug in scan tool?
    By Max Power in forum Duramax LLY
    Last Post: July 12th, 2006, 01:15 PM
