Results 1 to 5 of 5
Thread: Tried everything scan v7.5 fuel pids will not validate
    Jul 2018
    Default Tried everything scan v7.5 fuel pids will not validate
    hi , tried everything right click for more info but cannot validate gm.ibpw1,gm.ibpw2, e40ecm am I missing something
    attached pid list
    Jul 2018
    32 views no help
    Sorry, I somehow missed your thread
    Your ECM might not use GM.IBPW1/2... try GM.GM.INJPWB1/2 instead... if those work, I'll post the calc pid for duty cycle.
    Jul 2018
    I think I found it and put it in my calc_pids as such. Not sure if correct method but when you add text do you
    add to the one file ?
    The math symbols fell off of the two injector duty cycle pids, so I corrected it, see attached.
    Note: in this calc_pids.txt, the pid CALC.B0115 (CLC-00-260) uses data copied from table B0115; please check that this data matches your tune (table B0115).
  1. 1999 PCM wont validate Default Metric PIDS
    By bink in forum Petrol / Gas
    Last Post: September 10th, 2014, 01:50 PM
  2. PIDs won't validate with V1
    By ferocity02 in forum General
    Last Post: June 3rd, 2013, 04:26 AM
  3. cant validate rafig pids
    By rpmauto in forum General (Petrol, Gas, Ethanol)
    Last Post: April 2nd, 2010, 05:58 AM
  4. Can't Validate ETC PIDs
    By DrX in forum General
    Last Post: January 18th, 2010, 02:52 PM
  5. Can't get Boost PIDs to Validate??
    By 06bowtie_guy in forum Diesel
    Last Post: March 18th, 2007, 05:25 AM
