Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: EFILive Flash Scan V2 Black Box Help
    Aug 2018
    oh, from the pid list above, do this:
    remove these pids:
    GM.TCCSLIP
    GM.TRQENG
    add these pids:
    GM.IBPW1
    GM.IBPW2
    I'm not sure on the model, been in the car for a while. Right now the wideband isn't being plugged in to the flashscan, no hook up for it from the wideband. I'll have to look and see if I'm wrong there.
    I,ll swap out these pids tonight when I try to make it all happen
    Aug 2018
    The AEM wideband has a orange connector with just two wires in the connector. Where do I plug that into the flashscan?
    Quote Originally Posted by waggz View Post
    Turn your FSV2 over and look at the back of it...
    along the bottom edge, see the long/narrow orange socket...
    on the label next to this socket, look for AD1+ and AD1-
    wideband 0-5V signal connects to AD1+
    wideband signal ground connects to AD1-
    Aug 2018
    on the long/narrow orange connector label, look for AD1+ and AD1-1
    sent you a text, going to need more help than i thought.
    I edit my post above, I made it more specific, added a pic.
    I haven't received text or pm yet...
    Aug 2018
    strange, just sent you an e-mail with my number in cause there was an issue
    Apr 2008
    Wow I don't get on this forum much anymore as I really only deal with the same old stuff, and then I find my buddy asking about this stuff.
    For the record, it's set up on COS 5, I set it up and tuned it for him. I hadn't used BBL really at all, so I guess that's what he was trying to figure out. We did get it working. Good to know this forum is still a good working place for information unlike so many other forums at this point.
  9. #19
    I'm sorry, I did not see any emails (my email provider blocks @gmail and @yahoo)...
    it is easier for me if you post pics and files here.
  1. V2 black box computer cannot recognize black box?
    By ecc_33 in forum FlashScan V2
    Last Post: June 16th, 2011, 10:12 PM
  2. 1998 Black Box PCM Full Flash???
    By GAMEOVER in forum Vortec V6/V8 Specific
    Last Post: January 12th, 2011, 04:27 AM
  3. Flash Scan box to usb cable connection problems
    By cmitchell17 in forum FlashScan V1
    Last Post: July 3rd, 2009, 03:17 AM
  4. EFILive Version 8 (Black Box Logging) is now available
    By Blacky in forum Do you want to be a Beta Tester?
    Last Post: June 21st, 2009, 10:23 AM
  5. EFILIVE V8 Black Box Logging Questions - Imperial units?
    By Jasondt2001 in forum FlashScan V2 BB Logging
    Last Post: May 13th, 2009, 12:21 PM
