Results 1 to 4 of 4
Thread: Fuel trim jumps to -100%
    Jan 2009
    Default Fuel trim jumps to -100%
    Has anybody else experienced the STFT correction go to -100%? I'm trying to tune my 6.0L and during steady state it goes along well and then like a light switch the STFT pegs to -100%. I have STFT and LTFT off in the calibration, the closed loop temp set at 999. Any ideas?
    It looks like it transitions from VE to MAF, or vice-versa, and either table is way different (i.e. produces way different airmass/cylinder value than the other table).
    Or, if you're running VE only, then it might have a large step (large enough for the PCM's interpolation to produce a large value compared to previous value).
    Jan 2009
    For this log, I was SD only. I had already attempted to tune MAF only but had the same issue with the engine shutting down. I don't understand what you mean about the interpolation? Do you mean a smooth VE map with no drastic steps? If so, it's all a smooth transition thruout the map.
    Yes, smooth(er) VE with no big steps.
    Hmmm....
    post some more logs, and tune current file.
  1. Question about my fuel trim cells
    By n8dogg in forum Gen III V8 Specific
    Last Post: July 20th, 2011, 04:00 AM
  2. Fuel Trim help needed, please advise
    By kwhiteside in forum Gen III V8 Specific
    Last Post: August 26th, 2009, 06:15 AM
  3. Fuel Trim Cell Issue with 7.5
    By MoTruck in forum General
    Last Post: February 2nd, 2008, 05:26 AM
  4. Fuel Trim Cell PID
    By VetPet in forum Petrol / Gas
    Last Post: April 9th, 2007, 05:24 PM
  5. Fuel Trim Cell 10
    By eboggs_jkvl in forum General (Petrol, Gas, Ethanol)
    Last Post: December 20th, 2005, 11:24 AM
