Results 1 to 1 of 1
Thread: August 2018, Beta Update #4
    Default August 2018, Beta Update #4
    We strongly recommend that you do not install the beta software over the top of your production systems. It is possible that the beta test software may fail and your production system may not be recoverable. lf you conduct a tuning business, please take the necessary precautions to protect your business. EFILive recommends beta testers use a separate FlashScan V2 device (when installing the latest beta firmware) and only install the EFILive beta test software on a separate PC, laptop or virtual machine.
    Release Notes:
    Version Numbers:
    After installing this beta release you should have the following software, boot block, firmware versions installed:
    • EFILive V7 software: V7.5.23 To view the installed version, select Help->About (in the V7 Scan or Tune software).
    • EFILive V8 software: V8.2.19 To view the installed version, select Help->About (in the V8 Scan and Tune software).
    • Boot Block: V2.07.008 (Jul 4, 2018) To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
    • Firmware: V2.07.136 (Aug 28, 2018) To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
    Download here:
    Known Issues:
    Issue #1:
    Workaround:
    None.
    Issue #2:
    Workaround:
  1. August 2018, Beta Update #3
    Last Post: August 4th, 2018, 04:29 PM
  2. July 2018, Beta Update #2
    Last Post: July 18th, 2018, 02:22 PM
