Thread: controller identification
    Aug 2018
    Default controller identification
    i need help identifying which controller i have in my 2003 silverado 1500 2wd 4.3L serv# 12581565 hdw# 12575502
    Aug 2018
    from my understanding, it is the P59 PCM is this correct??
    if so, then which pcm do i select in the efi live v8 software tuning section. the only option that is close is the p04b "98-04 v6"
    LS1B, they were not listed by the GM name back when EFILive first came out, everyone knew them as the 'LS1 PCM'. That V6 PCM you mentioned was used on the 3.8L V6, not the 4.3L.
    By the way, if you are trying to read the ECM just press auto-detect, it should then automatically choose LS1B for you.
    Aug 2018
    okie dokie ty very much i tried auto detect but i get the $0101 error code right now my engine is in the shop being rebuilt, so i was thinking about making a bench harness as per efi documentation
    You're not connected to the PCM...?
    Aug 2018
    ok well i gusss this thread can be closed. i ended up making a bench harness and was able to connect to the computer and it identified as the LS1B thank you to those who helped
  1. Vortec PCM/Controller not listed under DVT controller selection.
    By Scatfish in forum Vortec V6/V8 Specific
    Last Post: April 5th, 2015, 12:10 PM
  2. Cadilac ECM Identification Help Please
    By Duramax 6.6L in forum Gen IV V8 Specific
    Last Post: December 16th, 2009, 03:35 PM
  3. Valve Bounce identification logging
    Last Post: June 1st, 2007, 01:01 AM
  4. Very High AutoVE values... Injector Size Identification?
    By dc_justin in forum General (Petrol, Gas, Ethanol)
    Last Post: November 18th, 2005, 07:44 AM
