Results 1 to 10 of 10
Thread: E78 - 2017 Sonic 1.4t Code 95 Code 84 on dash
    Aug 2018
    Exclamation E78 - 2017 Sonic 1.4t Code 95 Code 84 on dash
    Hello everybody,
    Need some help here, just flashed a 2017 Sonic 1.4T and 2 things are happening, once I connect the efilive unit on the OBD and the engine is on the code 95 pops up on the dash and gauges shut down, traction control light on and some others on, well I have to do logs so i am kind of blind, checked logs all ok and then removed everything went for a drive and 100 mts driving and code 84 on the dash, try to check DTC's with efilive, everything is clean, used launch scanner and clean, any clues to what might be happening, there is no apparent power loss when code 84 pops up.
    tahnks in advance,
    Alejandro
    Does it say "95" or "P0095" or "U0095"...?
    Aug 2018
    Nope it's just a "dash" code i cannot find anything doing a full scan sweep. I attach the results after flashing which I cleared and instantly after driving code 84 on dash
    https://imgur.com/a/SalVf64
    Aug 2018
    Joe, I made a test I installed the file without any mods (not original from the read out) and 3 mins afterwards same error on dash 84 so it seems it is something while writting.
    Does that error code go away...?
    ( during writing to the ECM, other modules can't talk on the CAN lan/bus, so they might emit a code (looks like dash did this) )
    Aug 2018
    Not at all drove it for a day with about 15 start/stop cycles to check and never went away.
    Quote Originally Posted by sama13 View Post
    Hello everybody,
    tahnks in advance,
    Alejandro
    Hi Alejandro,
    Are you saying that just connecting the FSV2 to the OBD-II port causes dash to display code 95 and gauges shutdown...?
    Are you sure your 2017 Sonic 1.4T has the E78 and not the E84 ECM (my 2017 Spark 1.4 uses the E84)...?
    Please post a pic of your engine bay showing the ECM.
    Aug 2018
    Hi Alejandro,
    HI Joe,
    When I connect it it literally goes dead and code 95 pops up after like 5 seconds.
    Well the auto detect provided the E78, check this info I did a prtscr
Name:	E78 Sonic.png
    I will take picture and post on monday
    You could try removing* pin 1 from the FlashScan OBDII cable. That pin is not used (never will be) but it is connected through to FlashScan and on some vehicles, PIN 1 is the low speed CAN bus. Sometimes FlashScan may cause interference on that pin causing modules that communicate over the low speed CAN bus to set trouble codes. Pin 1 is labelled on the OBDII cable end.
    First though, make sure you are using the latest boot block and firmware. Over the past few years we've updated the firmware to lessen the potential for interference on the low speed CAN bus.
    *removing means actually physically cutting the pin out of the end of the OBDII cable.
    Aug 2018
    OK I will remove.
    I have updated everything last week just to double check and same issue, instant issue when connecting will remove pin #1
  1. Replies: 3
    Last Post: October 29th, 2017, 01:06 PM
  2. Replies: 0
    Last Post: April 30th, 2017, 01:41 PM
  3. SONIC turbo - E78?
    By Boost in forum E78, E83, E84 PFI ECM's
    Last Post: February 1st, 2012, 10:24 AM
  4. SONIC turbo - E78?
    By Boost in forum E39, E80, E82 & E92 SIDI ECM's
  5. Code P062F and Code P0633 Help
    By Airtime in forum General (Diesel)
    Last Post: September 28th, 2009, 01:57 AM
