Results 1 to 4 of 4
Thread: OBDII J1996/M conneted to Ethernet (RJ45) pinout
    Aug 2018
    Default OBDII J1996/M conneted to Ethernet (RJ45) pinout
    We own several OBD2 Scanners that attach to DB9,s.
    A project we are doing requires us to pinout 2 OdbII (j1962/male) connectors to ethernet (RJ45).
    I am trying to pinout the Obd2 to ethernet with no luck
    anyone that can kindly assist us with the pinout for that?
    Below is how we connected a DB9. ( FYI )
    Respectfully,
    Michael Joy
    Systems Engineer
    856-879-4027
    For the EFILive cable you can get the details in this document:
    http://download.efilive.com/Tutorial...20Tutorial.pdf
    Oct 2019
    this doesn't tell you what wires from the rj45 connect to the obd2 im in Australia and looking at that link tells me nothing
    It tells you everything you need to know, to save you the trouble here it is.
    V2 RJ-45
    1 - 12V
    2 - CAN + (H)
    3 - CAN - (L)
    4 - GND
    6 - VPW
    8 - GND
    OBDII plug
    2 - VPW
    4 - GND
    5 - GND
    6 - CAN - (L)
    14 - CAN + (H)
    16 - 12V
    But if you are just going from RJ45 to OBD-II then why not use the supplied cable?
  1. help obd2 to rj45 cable
    By Eric in forum FlashScan V2
    Last Post: February 10th, 2016, 12:21 PM
  2. Replies: 0
    Last Post: August 13th, 2015, 04:40 PM
  3. OBDII codes
    Last Post: June 5th, 2008, 11:11 PM
  4. OBDII cables
    By limited cv8r in forum General
    Last Post: July 20th, 2007, 02:29 AM
  5. 2 OBDII Ports???
    By kbracing96 in forum General
    Last Post: August 31st, 2006, 05:28 AM
