Results 1 to 3 of 3
Thread: please help $0340 error code
    Aug 2018
    Default please help $0340 error code
    trying to flash a customers truck 2015 with 68rfe using hpp tunes set for csp5 switch. everything was going ok until the end when it stated error $0340 download not accepted. truck would not run. reflashed 3 times with no luck, finally found a stock file to flash back but now the cel light is on for def codes that were not present before. my program is up to date and firmware is also up to date. this is my first time flashing efi live myself, did I do something wrong or is the file bad? any help is appreciated!
    They contain anti-tuning protection, if you can't get in contact with HPP to get updated to the software releases that will get around that you'll need to download these two software versions and update everything yourself.
    https://forum.efilive.com/showthread...-Beta-Update-4
    Aug 2018
    That worked perfectly. Thank you very much
    I was not aware I had to download more software.
  1. 2015 cme $0340 error
    By comnrailpwr in forum Cummins 6.7L
    Last Post: April 14th, 2017, 05:01 AM
  2. 2008 with error code 0340.
    By Curt in forum Cummins 6.7L
    Last Post: December 18th, 2016, 10:15 AM
  3. $0340 error
    By billybob in forum Cummins 6.7L
    Last Post: February 16th, 2015, 03:42 AM
  4. help error 0340
    By easymon in forum Cummins 5.9L
    Last Post: September 25th, 2011, 10:24 AM
  5. Error $0340
    By comnrailpwr in forum Cummins 5.9L
    Last Post: August 15th, 2011, 06:53 AM
