Results 1 to 4 of 4
Thread: Saving Maps?
    Junior Member carneb's Avatar
    Default Saving Maps?
    I've been playing around with the scan tool making maps. I know I can save them individually once they are created, but is there any way to save what maps are displayed in the A to J positions? It seems sometimes I will create a map in one position, then close the scan tool and come back later and it will be gone. Other maps are still in the same spot though.
    Are the positions saved with something else, such as log files, PID selections or dashboards?
    Once you have created or loaded a map into a particular spot (A - J) then that map 'should' be there everytime you open the scantool.
    Try loading a MAP into a blank selection (A - J) and close the program down, then reopen it and see it the map is still assigned.
    Jan 2004
    Quote Originally Posted by GMPX
    Also, this will only work if you save them in the default MAP folder. If you save them to another folder other then this, when you open the scan tool, the corresponding maps for A-J will be blank if they weren't saved to the default folder.
    Quote Originally Posted by Black02SS
    Thats the answer then. When I would shut down the scan tool and then start it up again, not only was the map not in the same A-J location, I couldn't reload it either. Then I discovered that some of the maps were saving to the PID folder. All sorted now. Thanks for the help.
  1. sd card saving???
    By 2004gmc in forum Lounge
    Last Post: May 9th, 2009, 02:18 AM
  2. editing and saving PIDs / MAPs, VDPs
    By ZL1Killa in forum Gen III V8 Specific
    Last Post: April 7th, 2009, 03:41 AM
  3. Saving ECM/TCM Files
    By Cougar281 in forum General
    Last Post: July 17th, 2006, 10:37 PM
  4. Saving LTFT's with a data log...?
    By joecar in forum General
    Last Post: February 9th, 2006, 09:16 PM
  5. saving raw BIN files
    By SS2win in forum General (Petrol, Gas, Ethanol)
    Last Post: March 29th, 2005, 08:16 AM
