Results 1 to 4 of 4
Thread: RMA case
    Lifetime Member hymey's Avatar
    Jan 2008
    Default RMA case
    I have some issues with my flashscan with the USB port.I want to send back for repairs. I have been asked to create a RMA case. I have asked support how to and no reply. I have done some searches on the support page and the forum and I haven't found anything. ?
    Hymey, is it just a dodgy fitting connector? They are standard USB sockets, pretty easy to change for anyone who knows the hot end of a soldering iron from the cold end.
    If the unit is still in warranty that is a different story but I think you'll find if it isn't it'll be easier to have a local electronics shop repair it for you than send it back to NZ. Also, the repairs in NZ are not done in house, they are sent back to the manufacturer (still in NZ) so there could be some additional delays and expense if it is out of warranty.
    Jan 2008
    Thanks, my apologies it's the opposite end of the tool. The RJ45 female. And also require a new cable. I'd do it myself but I don't have the time atm.
    I'll send you a PM.
  1. 4.2 I6 Case
    By Tinbender59 in forum Petrol / Gas
    Last Post: January 17th, 2015, 03:51 PM
  2. CASE not getting copied into RR
    By Highlander in forum RoadRunner Real-Time PCM Emulator
    Last Post: September 17th, 2012, 03:14 AM
  3. CASE Learn on a RR?
    By N0DIH in forum RoadRunner Real-Time PCM Emulator
    Last Post: August 1st, 2009, 02:37 AM
  4. case relearn
    By 67LS3 in forum Gen IV V8 Specific
    Last Post: October 23rd, 2008, 02:52 PM
  5. V2 storage case
    By GAMEOVER in forum FlashScan V2
    Last Post: September 24th, 2008, 08:56 AM
