Results 1 to 10 of 10
Thread: Current Public Release (Sep 2018)
    Default Current Public Release (Sep 2018)
    Release Notes:
    Version Numbers:
    After installing this beta release you should have the following software, boot block, firmware versions installed:
    • EFILive V7 software: V7.5.24 To view the installed version, select Help->About (in the V7 Scan or Tune software).
    • EFILive V8 software: V8.2.20 To view the installed version, select Help->About (in the V8 Scan and Tune software).
    • Boot Block: V2.07.008 (Jul 4, 2018) To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
    • Firmware: V2.07.137 (Sep 6, 2018) To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
    Download here:
    Known Issues:
    Issue #1:
    Workaround:
    None.
    Issue #2:
    Workaround:
    Thanks.
    Oct 2018
    thanks for the sharing new version and mention the links for download but is there any new version of EFILive except V8
    Quote Originally Posted by Anatole View Post
    Not since Sept. 6, 2018.
    What in particular were you looking for...?
    Dec 2012
    Trying to do E41 User defined PIDs. All the DMA pids that I add seem to work correctly using the format provided, but when I try to add Enhanced Pids, the user PID compiler seems to Ignore them all. Not sure if this is a bug or there are limitations to what PRNs we are allowed to address or if the PRN is defined by EFI in the background, is it ignored?
    Josh
    '04 GMC LLY
    So these are just regular 2 byte PID numbers, eg PID $1234 = Engine RPM? (not correct but you know what I mean).
    Dec 2012
    indeed 2 byte with no symbols (such as # or $) just like in the example. When I go to the User Defined PIDs -> Descriptions folder, and look in the E41_Usr_Desc.txt file i can see the DMA pids listed at the end of the list, but the Enhanced pids are no where to be found.
    I tried to use PIDs that were already defined and redefine them with the "u" suffix (ex. uVOLTS = 1141) like in the example and it will detect those and the compiler will error saying "Duplicates Not Allowed" so its reading the PIDs and Enh data section.
    Ill keep trying other things to see if I can get you more data on the issue. Let me know if there is anything else you would like me to try.
    Josh
    '04 GMC LLY
    Are you defining the PIDs' scaling in the PIDs.ini file in the [Enh] section with the exact same PRN values as the PIDs you define in your E41.ini in the [EnhSup] section?
    And also make sure you have an "=" symbol after the PRN numbers in your E41.ini file, otherwise the *.ini file parser will ignore the line.
    Dec 2012
    Messed around with it some more.. still was frustrating. Ended up wiping v8 and 7.5, clearing the registry and reinstalling. Seems to have solved the problem??? Must have been some looming gremlin. But all is well now. Thanks!
    Josh
    '04 GMC LLY
  1. Current Public Release (May 2018)
    Last Post: July 5th, 2018, 11:36 AM
  2. Beta Test Release #3 (Apr 2018)
    Last Post: May 6th, 2018, 06:54 AM
  3. Beta Test Release #2 (Feb 2018)
    Last Post: March 19th, 2018, 05:54 PM
  4. Beta Test Release #1 (Feb 2018)
    Last Post: February 12th, 2018, 06:20 PM
  5. Sep 2015: EFILive Public Pre-Release
    Last Post: October 28th, 2015, 09:24 PM
