Results 1 to 7 of 7
Thread: Unrecognized PCM? 1997 Buick Skylark P08?
    Senior Member Wolfie's Avatar
    Dec 2007
    Default Unrecognized PCM? 1997 Buick Skylark P08?
    trying to check a read tune from a 1997 Buick Skylark, it is in the supported list.
    But when trying to open the P08_0091.ctz file, I get a pop up window stating it is a Unrecognized PCM... this version of the EFILive Tuning Tool has not yet been configured to display this controller's operating system...
    Wolfie
    LS1B 2007 Express 6.0 /w 470,000+ miles (parked as of 01April2011)
    I believe these are considered end-of-life and no support is available. What's the OS #, you could look on your PC under C:\Program Files (x86)\EFILive\V7.5\Calibrations\4CYL\ and see if there is a file for your OS.
    Dec 2007
    OK, The OS is 16250885 but the program says it's an Alternate OS Number. ,
    There is no file with that OS number.
    I realize it's unsupported now, but it shouldn't have been removed from the program as it once was supported.
    Wolfie
    I'm just trying to remember how these worked but I don't think they had an actual OS number as such.
    Unfortunately we won't be able to add new OS's in now but if you want you can send the .ctz to support@efilive.com and we can just see if it might be a simple fix vs an unmapped OS.
    Dec 2007
    e-mail sent.
    Wolfie
    Dec 2007
    Just received an email from Andrew Jensen EFILive Limited.
    he said
    "Hi Edward,
    I’m sorry that is not an operating system that we support. The controller used in that vehicle is also end of support, meaning that we will no longer release updates or create new OS support for them.
    The latest OS (one later than being used now) is also not supported. So there’s no real option for this one unfortunately.
    Regards,
    Andrew Jensen
    OK, but I had thought it was supported at one time because your web site says this.
    P08 - 97-02 4 Cylinder
    Cars
    97-98 Buick Skylark 2.4L
    but I guess I have a different 97 Buick Skylark.
    I wasn't disputing the fact that it was the end of life, but the software should still have read it as it was supported...
    Wolfie
    Hi Wolfie,
    The problem with these PCM's was the sheer number of OS's they released for them. With the Buick sharing the same engine, platform and PCM with other GM vehicles it is very difficult to ensure the supported vehicle list is 100% accurate for every year model. I have no doubt that a Skylark file was supported at some point which is why it is on the list but for your particular vehicle none of the calibrations released were even mapped out during the period that PCM was being worked on (based on what GM's CalID website says).
    I'm sorry we can't continue to add these OS's in now the PCM has retired from development.
  1. UNRECOGNIZED PCM Please Help!
    By cumminsDK in forum Cummins 6.7L
    Last Post: March 10th, 2016, 03:49 PM
  2. need help with a 99 buick 3.1 pcm
    By scott.baier in forum General
    Last Post: April 27th, 2011, 05:28 AM
  3. Unrecognized PCM
    By Meister in forum E37, E38 & E67 PFI ECM's
    Last Post: October 10th, 2010, 09:47 AM
  4. Unrecognized PCM...What needs to be done?
    By GAMEOVER in forum General
    Last Post: September 26th, 2010, 07:26 PM
  5. Unrecognized PCM
    By Rocketman69 in forum IL4, 97-01 PCM and 02+ P11 PCM
    Last Post: January 10th, 2008, 01:11 PM
