Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Calc.VET Logging Mistake is Where???
  1. #11
    Aug 2013
    lol, and not a good one at that, lol
    Don't sell yourself short.... you're one of the best moderators we've got.
  2. #12
    Aug 2013
    Quote Originally Posted by spedracr93 View Post
    Ya, I get it, I'm just trying to figure out what makes the most sense instead of arbitrarily replacing stuff.
    Let me help you with that one. What makes the most sense is to do some 'tests'. I would only recommend randomly replacing stuff if you exhaust all your testing options and still can't track down the problem... randomly replacing bits is the absolute last resort.
    Test for exhaust leaks by partially blocking the tailpipe (being mindful to create the restriction safely and securely, so whatever you're using to partially block the exhaust doesn't get shot out the pipe like a cannonball). Don't seal up the tailpipe completely, just enough to restrict the exhaust flow and allow some pressure to build up in the exhaust system... this will help you find even the smallest pinhole.
    Test for intake leaks by smoking the intake. You can take the vehicle to a workshop which has a smoke machine and have them smoke the intake for you... or if you're on a tight budget, you can smoke the intake yourself by purchasing a cheap cigar and filling the intake with smoke that you've made yourself.
    Test for leaking injectors by swapping the injectors bank to bank and do another log.... see if the rich bank stays the same or follows the injectors.
    When you do logs... make sure you log for misfires. Oxygen in the exhaust from a misfire will make the O2 sensor read lean. Sometimes misfires don't occur all the time, only under certain conditions... so don't rule out misfires until you've logged for it.
  1. Replies: 83
    Last Post: September 5th, 2023, 12:30 PM
  2. Calc VET Again
    By pormgb in forum Gen III V8 Specific
    Last Post: September 8th, 2013, 03:54 AM
  3. Replies: 1
    Last Post: April 11th, 2013, 04:28 PM
  4. Working on Calc.VET tune and getting odd data when logging
    By Hyper99 in forum Gen III V8 Specific
    Last Post: August 20th, 2012, 01:43 PM
  5. Calc.VET, VET Map Average is all 0.0?
    By n8dogg in forum Gen III V8 Specific
    Last Post: July 15th, 2011, 02:20 PM
