Results 1 to 4 of 4
Thread: 2011 lgh
    Aug 2018
    Default 2011 lgh
    Hi to all, this is my first try at tuning with Efilive, I just got a flashscan V2 (bought original file online) and I tried to de a full delete, I basically turned off and or zeroed every option related to emission, but that does not work, the throttle pedal does not work anymore, no code, no message. If I flash back to stock, pedal work again. Im I missing something or Efilive is not ok? Even if I do turn to ''0'' only one DPF or DEF switch, it does the same.
    May 2018
    Only 2011 have this issue, you need to find the correct combination.
    Sent from my S60 using Tapatalk
    Nov 2018
    Quote Originally Posted by Tintin View Post
    Did you find solution for this?
    Aug 2018
    As locksmith suggested, I started from scratch and tried different combination in adding one switch at a time, so far so good, all work great.
  1. LGH SOTF Tuning
    By BDDiesel1 in forum Duramax 2011+ LML / LGH
    Last Post: August 12th, 2017, 06:07 AM
  2. LGH 2011 CAL file OS 12646249
    By shay in forum Duramax 2011+ LML / LGH
    Last Post: May 3rd, 2016, 11:24 PM
  3. Stock LGH tune needed OS 12646249
    By rcr1978 in forum Duramax 2011+ LML / LGH
    Last Post: January 17th, 2014, 03:37 AM
  4. Lml / lgh
    Last Post: March 10th, 2011, 01:41 PM
  5. January 31st 2011 pre-release (Updated Feb 03, 2011)
    Last Post: February 24th, 2011, 06:14 PM
