Results 11 to 20 of 22
Thread: 97 c3500HD 454
    Quote Originally Posted by malibu795 View Post
    Same ecm
    Sorry malibu795 they aren't the same ECM's, the 96-97 had one type, then it changed again for 98-00 (the one we supported but have since retired active work on).
    Dec 2007
    Can it still have the 411 swap done?
    I don't know sorry, I'm not sure what is actually involved in that process.
    Feb 2005
    yes it can. Lextech has the spreadsheet for it. I've done a 97 and a 99.
    2001 Camaro SS
    EFILive Custom OS3
    Dec 2007
    Already Sent him a PM..
    Dec 2007
    been going through it... been getting lean burn codes on the O2 and 1406, above 1/2 throttle engine tends to lay over on power dragging a 7k trailer and gets more noticeable the heavier I get...
    cant get the fuel system lined out... new filter/fuel pump w/sock/injectors..
    all data has 56-62psi for specs
    key on fuel pressure 46psi
    key off fuel pressure drops almost instantly to 15-20psi
    free rev drops to 40psi from 46psi
    all pressures measured at test port.
    putting a 340LPH pump in the tank will probably mask the problem due to shear volume of fuel sent..
    picked up adapter to swap line to -6 AN to run from tank to engine for supply and return incase one of the steel to hose transitions pealed over and is restricting flow..
    fuel pressure regulator is vacuum controlled
    both FPR and fuel pump are under 12M warranty...getting new FPR tomorrow
    could I have a gotten a bad fuel pump?
    have exhaust (dual 3" ) and 0411 ECM waiting to go one... get one problem fixed at a time...
    Dec 2007
    Here's some stuff I do with it.. grossed 25k
    Dec 2007
    upon further parts review.. fuel pump I got is rated at 35GPH and 85psi swapping it out got the 58gph/110psi version
  9. #19
    Dec 2007
    Swapped fuel pump hits 62psi with key on then drops to 58psi, used the bigger pump I mentioned
  10. #20
    Dec 2007
    after multiple attempts... engine had no power... yanked the MPFI system off, put a MSD 6AL with blaster SS coil billet dis, edelbrock performer intake, fast ezi efi 1.0, oem fuel pump.. also swap to adjustable valve train with 1.7 roller tip rockers. comp cam conversion stud is #4514-16 ~$90.00 since I already did the 0411 swap ill turn all the SES codes off..
  1. 454 411 Swap
    By Supercharged111 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 26th, 2019, 04:17 PM
  2. Vortec 454 swap
    By blazinblue in forum Vortec V6/V8 Specific
    Last Post: April 16th, 2012, 03:23 PM
  3. 454 Wont start.
    By notgoodenugh in forum Vortec V6/V8 Specific
    Last Post: February 4th, 2012, 12:30 PM
  4. 2000 1ton 454 help
    By mytoyz in forum Tuning For Economy
    Last Post: April 1st, 2011, 11:49 AM
  5. 98 Vortec 454
    By knagel in forum Vortec V6/V8 Specific
    Last Post: October 7th, 2008, 02:21 PM
