Ok, so its has been a long while since I have used EFIlive to tune on my camaro. I spun a bearing on it a few years ago and I am just now getting it back up and running. With the built motor i'm getting the idle dialed in etc...
there have been several software upgrades and firmware upgrades on the v2.
My issues is I had wired up a fuel pressure sensor into the V2. However, it isn't reading fuel pressure. I tested and am getting the correct 2.5volts. Is there anything else i need to do? was something maybe lost in the firmware upgrade. I briefly scanned over the old tutorial on how to set it up but nothing stood out that i have wrong. I am using the external 1 input, which looking at the face of the v2 is the furthest right ports.
any suggestions, tips or tricks i need. I would like to log fuel pressure with this larger motor to make sure my pumps can keep up.
