Somewhere along the way I started getting this error on the LLY's and running scripts give same error types. 8.2.19 version
Hi Mike, what version of V7 are you running there? That was a bug in one of the previous betas.
From the current release notes:
Build V7.5.24 Bug FIxes:
- When displaying a user defined cax definition, if the data scaling offset is non zero (and greater than 1.5) then the message: "Axis Maximum Value must be >= Minimum." may be displayed and the cax definition will not load correctly.
It may be related to what you are seeing there, would be worth updating just to see.
http://www.efilive.com/latest/septem...ublic-release/
