Results 1 to 10 of 17
Thread: 2005 Silverado Installing ethanol content sensor
    Apr 2018
    Default 2005 Silverado Installing ethanol content sensor
    Hey guys looking to install ethanol content sensor in 2005 silverado. Is this possible with out too much hassle. I’m running the custom os2 for valet mode and upgrading fuel system
    Does your OEM/base OS support physical alcohol content sensor...?
    Apr 2018
    It is not a flex fuel truck stock. I was just curious if i wired a sensor up and turned the tables on for the sensor in the tune if it would work and if not what I would need to do to make it work
    I think you would have to attempt to run a factory tune that already had the FlexFuel active, there is a lot of tables and parameters in the background that need to be set up and may have never been populated in some applications where FlexFuel was never going to be an option. It isn't as simple as flicking the FlexFuel enable switch and it all works.
    Apr 2018
    I’ve got a flex fuel tune I’ve saved from a different vehicle on my laptop and it seems to have all the same tables as mine. I would copy those tables to mine. Just curious if this would work or if anyone has done it.
    No that isn't what I meant, the tables you see in EFILive are only a small part of the story. There is a lot of obscure tables and parameters in the background not shown in EFILive that are required to work as well.
    Apr 2018
    Ah I see. Thank you
    Apr 2018
    Did some digging and would it be possible to do a segment swap and cal flash it in? Having the capability to automatically switch back and forth between fuels would be nice
    Whilst that is possible it swaps everything in that segment which means every parameter/table (visible and not visible) from the E85 calibration goes in to your vehicle. That could cause problems with different vehicle configurations. An extreme example would be to swap a Corvette segment in to a truck would cause all sorts of issues.
    Apr 2018
    I found a file with the same os number and same year just with flex fuel enabled. I might give it a shot and if it doesn’t work i can always go back. Thank you for answering my questions. I’m planning on adding boost and just looking for a little flexibility with fuel options.
  1. Flex Fuel Foruth-Gen Camaro Ethanol Sensor PID
    By ChaseChris8 in forum Gen III V8 Specific
    Last Post: August 1st, 2019, 01:27 PM
  2. Ethanol Sensor on MAF circuit LS1
    By macca_779 in forum Petrol / Gas
    Last Post: January 24th, 2014, 02:01 AM
  3. 2005 Silverado New Built LQ4 No start
    By 2005 silverado in forum Gen III V8 Specific
    Last Post: November 7th, 2012, 05:05 PM
  4. 2005 silverado 5.3 need some tuning pointers
    By whiteboy631 in forum Gen III V8 Specific
    Last Post: December 22nd, 2010, 10:00 AM
  5. Installing the 2 Bar MAP Sensor tonight... Advice???
    By nonnieselman in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: June 11th, 2007, 05:22 PM
