Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: 2005 Silverado Installing ethanol content sensor
    Mar 2009
    Quote Originally Posted by Andyb756 View Post
    I found a file with the same os number and same year just with flex fuel enabled. I might give it a shot and if it doesn’t work i can always go back. Thank you for answering my questions. I’m planning on adding boost and just looking for a little flexibility with fuel options.
    This requires a full flash, not a simple flick of the switch or mere segment swap. It has been done on LS1Tech though. I was initially thinking LS1b.
    https://forum.efilive.com/showthread...OS-for-LS1-PCM
    But the GenIV stuff is similarly simple.
    http://www.trucktrend.com/how-to/eng...or-more-power/
    Apr 2018
    Yeah gen lv stuff looks way simpler. From what I’m reading I have a p59 ecm with green connector which has dbw which I don’t plan to change from. There is kind of a rabbit hole of information to jump down with this topic all which has no real clear cut solution haha. I have built a file with engine and fuel system segments and also a complete file from a same year same os dbw flex fuel truck. I’ll play with this and see what works and report back
    Jan 2010
    The 05 uses a virtual flex table based of 02 sensor feedback, however if you wire up an ethanol content sensor, it will read from the sensor.
    As mentioned, You need to do a full flash from a real flex fuel enabled operating system.
    Apr 2018
    Ok I will definitely do that. I ordered a sensor and pigtail off eBay and will be doing flex capable pump and injectors as well. When it all shows up I plan to spend a Saturday installing and adjusting tune if need be
    Jul 2003
    What operating system are you trying to enable...
    Apr 2018
    Ok everybody my sensor and pigtail made it all the way from China yesterday to my home. 43 dollars and 3 weeks later I’m flex fuel capable. I made a line to connect the sensor in between the rail and supply line. I segment swapped engine parameters with a same year flex capable avalanche and scripted my settings back in all tables except flex fuel tables and full flashed my pcm. Wired sensor in and read 6.6 percent. I’ve been running 87 e10 so possibly they were a bit low on the corn. I had half a tank and 4 gallons on non ethanol fuel so I dumped that in and test drove. During drive it dropped down to 4 percent and the sensor reads at 54 hz and zeros out in scanner if I unplug. Seems all is working well and I want to grab some e85 and see if alcohol content reads accordingly. Bigger injectors and fuel pump to follow before I’ll fill up with e85. One question if anyone can answer is what do you set b3103 flex fuel default percentage at? I set it at 10 since that’s what the pump said it could be at.
    Apr 2018
    Put 5 gallons of e85 in and ran it with success. Pump said anywhere from 50 to 83 percent ethanol. After 2 minutes or so of driving ethanol content rose to 21 percent and stayed. I was shooting for somewhere in that range don’t want to run it lean and I haven’t gotten injectors yet. Throttle response is smooth and no knock retard at all.
  1. Flex Fuel Foruth-Gen Camaro Ethanol Sensor PID
    By ChaseChris8 in forum Gen III V8 Specific
    Last Post: August 1st, 2019, 01:27 PM
  2. Ethanol Sensor on MAF circuit LS1
    By macca_779 in forum Petrol / Gas
    Last Post: January 24th, 2014, 02:01 AM
  3. 2005 Silverado New Built LQ4 No start
    By 2005 silverado in forum Gen III V8 Specific
    Last Post: November 7th, 2012, 05:05 PM
  4. 2005 silverado 5.3 need some tuning pointers
    By whiteboy631 in forum Gen III V8 Specific
    Last Post: December 22nd, 2010, 10:00 AM
  5. Installing the 2 Bar MAP Sensor tonight... Advice???
    By nonnieselman in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: June 11th, 2007, 05:22 PM
